Modules/SA-Tracks for Samsung HD250HJ
Posted: 30.10.08, 14:50
by swersig
i need Modules/SA-Tracks for Samsung HD250HJ, TRIDENT3, Flash-Code fh06s88.
Can anyone help?
Thanks in advance,
Stephan
Re: Modules/SA-Tracks for Samsung HD250HJ
Posted: 10.11.08, 16:33
by swersig
Thanks for the reply.
Currently i cannot test them because the hdd is in debug mode. Is there any way to make the drive boot up in normal mode or leave the debug mode? When i received it, it stayed busy but after a soft reset i was able to backup the sa tracks (at that time, pc3k didnt support trident3) and there were some bad sectors (3 sectors on head 0 and 1 each, same sectors on both heads). I guess i put it in debug mode. Soft-reset doesnt do the trick. Thanks again for your help,
best regards
Stephan
