WD10JPCX-24UE4T0 Need Urgent
Posted: 31.12.23, 11:29
by O.S
:wave: Hi.. Everyone
Happy a new year
I read WD10JPCX-24UE4T0 firmware once, after connect it to external power supply has 12.60 Volt outpot and heating spindle motor a little, then PC-3000 Identify the name and serial number and backup some modules extremely slow and a lot of errors.
I tried load LDR from original module it hung up at the end of loading and identified XYZ with 0 size, not failed to create ROM from SA . 109 is missing, Error 0D
Guide me please .
without that procedure PC-3000 always gave me 0 size no drive name or SN , but motor still running .
I tried to build ROM from SA, but there is no 109 module.
I tried to solve Slow respond by slow respond Technic, but it didn't t succeed.
I replace PCB same problem.
Please I need a full set firmware especially ( LDR Module 02 Module 109 ROM Modules )for WD10JPCX-24UE4T0 FW ver: 0016000T
Date 11-NOV-2013
DCM-SB0TJHB
Made in : Malaysia
ROM Version16.0TG
Version................................. : 0x0002
Controller firmware revision............ : 16.0TG
Servo firmware revision................. : N0.18
Overlay firmware revision............... : 16.0UG
Surface format revision................. : A1.004
Read channel firmware revision.......... : G.00031A
Drive type.............................. : Mobile 2.5 Inch
Interface type.......................... : Serial ATA
PCBA type............................... : Entek rev 0
ROM type................................ : Serial Flash
Flash size (page size).................. : 256 (4) kB
DRAM size (allocated)................... : 16384 (12169) kB
Drive Parts Information
Controller chip vendor.................. : 0x0000
Controller chip revision................ : 0xA5C0 88i9446C0
MicroP vendor........................... : 0x0000
MicroP revision......................... : 0xA5C0
Channel chip vendor..................... : 0x00E9
Channel chip revision................... : 0x0021
Preamp vendor........................... : 0x0001
Preamp revision......................... : 0x0000
Power chip vendor....................... : 0x0000
Power chip revision..................... : 0x9022
Drive Build Information
Product ID (Ext)........................ : 0x16FE (0x0203)
Model................................... : WDC WD10JPCX-24UE4T0
Serial number........................... : WD-WX81E73FFZP3
DCM..................................... : S|BQL|PGMZHXCVRHVHKYUD
Original built date..................... : 11-12-2013
Reconfiguration date.................... :
Drive platters.......................... : 2
Physical heads.......................... : 4
Virtual heads........................... : 4
Depop bit map........................... : 0x0F
Zones................................... : 61
Servo wedges............................ : 296
Negative cylinders...................... : 256
Spindle RPM............................. : 5419
User cylinders.......................... : 0
Cylinder wedge skew..................... : 31
Head skew............................... : 78
Cluster skew............................ : 112
Error Correction Information
No. of interleaves in OTF............... : 0
Number of ECC + CRC Bytes............... : 0
No. of bytes(symbols) corrected by OTF.. : 0(0)
No. of bytes(symbols) corrected by FW... : 0(0)
Feature flags........................... : 0x0DC3FDB6
Jumper Settings
Jumper setting value.................... : 0x0000
Master jumper........................... : OFF
Slave jumper............................ : OFF
CSEL jumper............................. : OFF
ReloList File Information
Number of relocations................... : 0
Number of tares......................... : 0
Number of Ftares........................ : 0
Max remaining possible relos............ : 0
Number of consumed spares............... : 0
Last LBA of spare pool.................. : 488 431 440
Drive Format Information
Tracks per inch (in KTPI)............... : 0
Area Density in 100MB (per platter)..... : 1250
Format Type(0).......................... : primary format
SATA IPM Timers
Partial................................. : 5 ms
Slumber................................. : 100 ms
Re: WD10JPCX-24UE4T0 Need Urgent
Posted: 02.01.24, 09:58
by rezafarah
Posted: 03.01.24, 19:42
by O.S
Thank you Mr. Rezafarahm for your respond, I Need same module WD10JPCX-24UE4T0 witch has same ROM Version.
I read damaged HDD modules by Composite reading but the problem is not solved.( XYZ and Zero with 0 size ) after ATA uploading to RAM.
please refer the screen shoots
firmware for WD10JPCX-24UE4T0 FW ver 0016000T.jpg (9.11 KiB) Viewed 21084 times
to identify the problem.
Posted: 03.01.24, 20:09
by digitalsupport
Dear O.S
If this is a drive for testing only, tell us what procedures you have tried?
If this is a client case, please reach out to ts and open a ticket to prevent data loss.
Posted: 07.01.24, 00:12
by O.S
This drive for an informatics engineer client, he is an Informatics Engineer, Deal with it randomly without data recovery tools and Knowledge.
So I need Identical firmware 001600TG 11-NOV-2013, to Upload it into RAM and generate ROM from SA.
HDD surgery has no Identical firmware donor, HDD guro and HD Oracle although.
if some fellow help me with Identical firmware i will thanks-full for him.
My best regard
