I need WD3200AAJS-00L7A0 FW
hassan
Postby hassan » 07.10.10, 15:30
I need WDC WD3200AAJS-00L7A0 modules
SA version : 000300E2
Re: I need WD3200AAJS-00L7A0 FW
Postby AJ2008 » 07.10.10, 15:53
I have this but cannot upload here.
You have email I can send to?
hassan
Postby hassan » 07.10.10, 17:17
Thank you AJ2008
my mail is :
hdd@jrida.com
Best Regards.
Hassan Jrida.
hassan
Postby hassan » 12.10.10, 10:32
I have got the FirmWare frome AJ2008 but this is the problem:
When power on the drive it's show it's ID but can not access user data because of many corrupted modules
Level "A" modules:
(03 , 41 , 42 , 43 , 49 , 4A , 4D ) are corrupted
Level "B" nodules
001F , 006E , 0029 , 004E , 0004 , 0038 , 002E , 006B , 006F
also corrupted
and many othe corrupted modules have no importance level as (0121 , 0116 ...)
I try to over write the level "B" corrupted modules from the file which i get from AJ2008 the write complete without any error also i check all writen modules all was ok
when power off /on the drive remain busy for about 4 min the motor off and show ABR error
Postby AJ2008 » 12.10.10, 10:56
I think the biggest problem are damage to all 4x modules, these are all adaptive modules.
Can you read with composite read? Or can SA tracks be read?
If SA tracks can be read, is possible to recover SA modules from there. As far as I am aware all SA modules on ROYL have unique signiture so can be found in tracks if you know correct size of modules
hassan
Postby hassan » 12.10.10, 14:05
I am reading the SA tracks but how can i extract the modules from the tracks files
In odules Dir i can get the size of modules
how can i convert between ABA and CHS
hassan
Postby hassan » 13.10.10, 11:32
I read SA Tracks but it is contain many erorr
Tiffany and Tiago
Postby Tiffany and Tiago » 11.09.23, 21:17
Hi! i need some resources on this model as well, but i need for the FW 500E6.
I need because of the specifically Donor ROM
regards :D
