Good day,
We have a Western Digital that gives a (0)MB capacity problem and we can't access the modules. For this we would need the LDR-File, which we unfortunately do not have.
We have contacted Technical Support, but they do not have such a file available and suggested we source it from the Forum.
Firmware Version on ROM is: 00510022
Your assistance will be greatly appreciated!
Kind Regards,
Luzette Reyneke
LVC Data Recovery
WD10EARX LDR Needed (ROM F/W 00510022)
- silenthunter
Re: WD10EARX LDR Needed (ROM F/W 00510022)
Post full model and family.
- datasolution
hi,
do you search for this model than i have.pls give me your email id.
Sadle 2D\WDC WD10EUCX-63YZ1Y0-51-0AB52
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 3
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 2005
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 256 Kb
>ROM version............................. : 51.22A
>ROM generation.......................... : 51.23A
>Link table version...................... : 00.09.
>Consolidated ROM version................ : 00510022
>ROM Modules:
>Flash ROM dir reading................... : Ok
>Flash ROM dir reading (Ext)............. : Ok (Active)
>Modules directory address............... : 366 408
>SA regions address...................... : by default
>SA Translator loading................... : Ok
!SA defects assigned..................... : 1
>Heads configuration..................... : by map
>Heads number in use..................... : 3
>Switched off heads...................... : No
>Heads map............................... : 0,1,2
>ROM Firmware version.................... : 00510022
>Service area:
>Permanent overlay....................... : Loaded
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
>RAM:
>ROM:
>ROM Modules:
>Service area:
- silenthunter
Thanks for getting back to us.
It does spin up and comes ready.
Utility can be read and not spinning down.
PCB board is native.
The Full specs of the HDD is Western Digital 3.5"1TB SATA
Model: WD10EARX - 00N0YB0
Serial Nr: WCC0T0359717
Family: Sadle 2D
64MB Cache
Date: 7 Sept 2011
Manufactured in Thailand
Please let me know if this information is sufficient.
Thank you for your feedback!
Kind Regards,
Luzette Reyneke
LVC Data Recovery
Family: Sadle 2D
64MB Cache
Date: 7 Sept 2011
Kind Regards,
Luzette Reyneke
LVC Data Recovery
