Hi !
I search all modules for a fujitsu MAW3073NC (firmware version 2904)
(or if you can't upload all ... just number 09/0D/0E/2E/7B/82/83/84/85/E0)
Thanks !
search firmware for a fujitsu MAW3073NC
- avenger-fr
- avenger-fr
Re: search firmware for a fujitsu MAW3073NC
Hi !
Finnaly I have found a other drive Fujitsu MAW who works well (it's have only a firmware marked bad : TO).
I have try to repair all bad firmwares with it but the module LOG write well and read bad after an off/on, and the drive is always recognized in 48Mb. I have validate the two head with the function Service Information Object : tracks. I can read some user data on some tracks (on the two head) with this function, but without the Plist...
I have already try the hotswap but without success.
I don't know what I must do...
Anybody can help me ???
Thanks !
All the logs :
Thanks !
All the logs :
SA structure test
Heads map............................... : OK
Reading modules...
DM...................................... : OK
GL...................................... : OK
DT...................................... : OK
DI...................................... : OK
PG...................................... : OK
SCYL.................................... : OK
MS...................................... : OK
RI...................................... : OK
DI2..................................... : OK
SKIP.................................... : OK
DRVP.................................... : OK
LOG..................................... : ASPI Command exec error - Read module error (Id: D)
TO...................................... : ASPI Command exec error - Read module error (Id: E)
HDA..................................... : OK
SCHD.................................... : OK
SDTP.................................... : OK
JUDG.................................... : OK
ERKD.................................... : OK
SMDT.................................... : OK
SQDT.................................... : OK
ENDL.................................... : OK
DEF0.................................... : OK
DEF1.................................... : OK
CORM.................................... : OK
TPIM.................................... : OK
VMMM.................................... : OK
OFSM.................................... : OK
PL...................................... : OK
PRSV.................................... : OK
TS...................................... : OK
CS...................................... : OK
FSKW.................................... : OK
SASL.................................... : OK
ICYL.................................... : OK
ZONE.................................... : OK
MR...................................... : OK
SCRT.................................... : OK
EV01.................................... : OK
APPL.................................... : OK
STL..................................... : OK
LOG2.................................... : OK
ELG0.................................... : OK
ELG1.................................... : OK
ELG2.................................... : OK
ELG3.................................... : OK
ELG4.................................... : OK
ELG5.................................... : OK
ELG6.................................... : OK
ELG7.................................... : OK
ELG8.................................... : OK
ELG9.................................... : OK
ELGA.................................... : OK
ELGB.................................... : OK
ELGC.................................... : OK
ELGD.................................... : OK
ELGE.................................... : OK
ELGF.................................... : OK
POSQ.................................... : OK
PSM0.................................... : OK
PSM1.................................... : OK
PSM2.................................... : OK
PSEO.................................... : OK
DI3..................................... : OK
SSKW.................................... : OK
DCST.................................... : OK
SIDE.................................... : OK
SCTR.................................... : OK
CSSM.................................... : OK
VGAM.................................... : OK
ASYM.................................... : OK
LOG0.................................... : OK
LOG1.................................... : OK
FA00.................................... : OK
FA01.................................... : OK
FA02.................................... : OK
FA03.................................... : OK
FA04.................................... : OK
FA05.................................... : OK
SVL0.................................... : OK
SVL1.................................... : OK
SVL2.................................... : OK
SVL3.................................... : OK
SVL4.................................... : OK
SVL5.................................... : OK
SVL6.................................... : OK
SVL7.................................... : OK
SVL8.................................... : OK
SVL9.................................... : OK
SVLA.................................... : OK
SVLB.................................... : OK
SVLC.................................... : OK
SVLD.................................... : OK
SVLE.................................... : OK
SVLF.................................... : OK
CS1..................................... : OK
PLIST reading........................... : ASPI Command exec error - Read PList error
GLIST reading........................... : ASPI Command exec error - Read module error (Id: 1)
Duration................................ : 00:00:55
HDD Self Test
SCSI CDB Sent........................... : 1D 04 00 00 00 00
SRB Status.............................. : 04 [SRB completed with error]
Host Adapter Status..................... : 00 [Host adapter did not detect error]
Target Status........................... : 02 [Check Condition]
Sense Key............................... : 04 [Hardware Error]
Additional Sense Code................... : 4C
+Sense Code Qualifier................... : A7 []
Fujitsu Vendor Specific (UEC)........... : Logical unit failed selfconfiguration. The IDD's initial setup failed. SA Read error (any 4/44/** error during SA read).
Ok
SA STRUCTURE
SERVICE AREA PARAMETERS
Zone #.................................. : 0
Initial cylinder........................ : -4
Final cylinder.......................... : -143
SPT..................................... : 715
Heads map............................... : 01 00
ZONE ALLOCATION TABLE
Number of zones......................... : 18
# : Head : Initial cylinder : Final cylinder : SPT :
1 : 0 : 0 : 4 256 : 1 185 :
1 : 1 : 0 : 4 408 : 1 165 :
2 : 0 : 4 257 : 8 541 : 1 165 :
2 : 1 : 4 409 : 8 846 : 1 140 :
3 : 0 : 8 542 : 12 854 : 1 140 :
3 : 1 : 8 847 : 13 313 : 1 140 :
4 : 0 : 12 855 : 17 195 : 1 140 :
4 : 1 : 13 314 : 17 809 : 1 102 :
5 : 0 : 17 196 : 21 564 : 1 094 :
5 : 1 : 17 810 : 22 334 : 1 071 :
6 : 0 : 21 565 : 25 961 : 1 064 :
6 : 1 : 22 335 : 26 888 : 1 042 :
7 : 0 : 25 962 : 30 386 : 1 026 :
7 : 1 : 26 889 : 31 471 : 1 026 :
8 : 0 : 30 387 : 34 867 : 997 :
8 : 1 : 31 472 : 36 112 : 977 :
9 : 0 : 34 868 : 39 348 : 957 :
9 : 1 : 36 113 : 40 753 : 940 :
10 : 0 : 39 349 : 43 857 : 929 :
10 : 1 : 40 754 : 45 423 : 912 :
11 : 0 : 43 858 : 48 366 : 912 :
11 : 1 : 45 424 : 50 093 : 874 :
12 : 0 : 48 367 : 52 875 : 855 :
12 : 1 : 50 094 : 54 763 : 843 :
13 : 0 : 52 876 : 57 356 : 820 :
13 : 1 : 54 764 : 59 404 : 810 :
14 : 0 : 57 357 : 61 725 : 798 :
14 : 1 : 59 405 : 63 929 : 775 :
15 : 0 : 61 726 : 65 870 : 749 :
15 : 1 : 63 930 : 68 222 : 741 :
16 : 0 : 65 871 : 69 875 : 716 :
16 : 1 : 68 223 : 72 370 : 706 :
17 : 0 : 69 876 : 73 768 : 684 :
17 : 1 : 72 371 : 76 402 : 684 :
18 : 0 : 73 769 : 73 770 : 655 :
18 : 1 : 76 403 : 76 404 : 646 :
MODULES TABLE
: ID : Module : Length : Read : ChSum :
: 00 : DM : 188 : OK : OK :
: 01 : GL : 156 : OK : OK :
: 02 : DT : 256 : OK : OK :
: 03 : DI : 1 : OK : OK :
: 04 : PG : 141 : OK : OK :
: 05 : SCYL : 18 : OK : OK :
: 06 : MS : 2 : OK : OK :
: 08 : RI : 2 : OK : OK :
: 09 : DI2 : 1 : OK : OK :
: 0A : SKIP : 1 : OK : OK :
: 0B : DRVP : 36 : OK : OK :
: 0D : LOG : 85 : Err : -- :
: 0E : TO : 12 : Err : -- :
: 0F : HDA : 1 : OK : OK :
: 10 : SCHD : 64 : OK : OK :
: 11 : SDTP : 6 : OK : OK :
: 12 : JUDG : 3 : OK : OK :
: 13 : ERKD : 2 : OK : OK :
: 14 : SMDT : 3 : OK : OK :
: 15 : SQDT : 16 : OK : OK :
: 16 : ENDL : 5 : OK : OK :
: 17 : DEF0 : 256 : OK : OK :
: 18 : DEF1 : 256 : OK : OK :
: 19 : CORM : 8 : OK : OK :
: 1A : TPIM : 60 : OK : OK :
: 1B : VMMM : 60 : OK : OK :
: 1C : OFSM : 60 : OK : OK :
: 1D : PL : 188 : OK : OK :
: 1E : PRSV : 5 : OK : OK :
: 20 : TS : 21 : OK : OK :
: 21 : CS : 12 : OK : OK :
: 22 : FSKW : 3 : OK : OK :
: 23 : SASL : 1 : OK : OK :
: 24 : ICYL : 63 : OK : OK :
: 25 : ZONE : 600 : OK : OK :
: 28 : MR : 1 : OK : OK :
: 2A : SCRT : 2 : OK : OK :
: 2B : EV01 : 190 : OK : OK :
: 2C : APPL : 34 : OK : OK :
: 2D : STL : 1 : OK : OK :
: 2E : LOG2 : 400 : OK : OK :
: 30 : ELG0 : 200 : OK : OK :
: 31 : ELG1 : 200 : OK : OK :
: 32 : ELG2 : 200 : OK : OK :
: 33 : ELG3 : 200 : OK : OK :
: 34 : ELG4 : 200 : OK : OK :
: 35 : ELG5 : 200 : OK : OK :
: 36 : ELG6 : 200 : OK : OK :
: 37 : ELG7 : 200 : OK : OK :
: 38 : ELG8 : 200 : OK : OK :
: 39 : ELG9 : 200 : OK : OK :
: 3A : ELGA : 200 : OK : OK :
: 3B : ELGB : 200 : OK : OK :
: 3C : ELGC : 200 : OK : OK :
: 3D : ELGD : 200 : OK : OK :
: 3E : ELGE : 200 : OK : OK :
: 3F : ELGF : 200 : OK : OK :
: 52 : POSQ : 70 : OK : OK :
: 53 : PSM0 : 256 : OK : OK :
: 54 : PSM1 : 256 : OK : OK :
: 55 : PSM2 : 256 : OK : OK :
: 56 : PSEO : 256 : OK : OK :
: 59 : DI3 : 1 : OK : OK :
: 5A : SSKW : 58 : OK : OK :
: 60 : DCST : 16 : OK : OK :
: 61 : SIDE : 32 : OK : OK :
: 62 : SCTR : 256 : OK : OK :
: 63 : CSSM : 6 : OK : OK :
: 65 : VGAM : 60 : OK : OK :
: 66 : ASYM : 60 : OK : OK :
: 7A : LOG0 : 400 : OK : OK :
: 7B : LOG1 : 400 : OK : OK :
: 80 : FA00 : 200 : OK : OK :
: 81 : FA01 : 200 : OK : OK :
: 82 : FA02 : 200 : OK : OK :
: 83 : FA03 : 200 : OK : OK :
: 84 : FA04 : 200 : OK : OK :
: 85 : FA05 : 200 : OK : OK :
: A0 : SVL0 : 256 : OK : OK :
: A1 : SVL1 : 256 : OK : OK :
: A2 : SVL2 : 256 : OK : OK :
: A3 : SVL3 : 256 : OK : OK :
: A4 : SVL4 : 256 : OK : OK :
: A5 : SVL5 : 256 : OK : OK :
: A6 : SVL6 : 256 : OK : OK :
: A7 : SVL7 : 256 : OK : OK :
: A8 : SVL8 : 256 : OK : OK :
: A9 : SVL9 : 256 : OK : OK :
: AA : SVLA : 256 : OK : OK :
: AB : SVLB : 256 : OK : OK :
: AC : SVLC : 256 : OK : OK :
: AD : SVLD : 256 : OK : OK :
: AE : SVLE : 256 : OK : OK :
: AF : SVLF : 256 : OK : OK :
: E0 : CS1 : 192 : OK : Err :
PLIST - DEFECTIVE SECTORS LIST
Number of defects : 0
: NN : Cylinder : Head : Sector :
GLIST - REASSIGNED SECTORS LIST
