SMART at Quantum HDD Topic is solved
Moderators: Nick_TS, Filipp_TS
Yuriy Manjilevskiy
Postby Yuriy Manjilevskiy » 23.08.07, 14:55
It was repeatedly noticed that SMART attribute N195(Hardware ECC Recovered) on last Quantum models(including Quantum-Maxtor models) reflects the condition of heads. If its number rapidly began to fall(noticeably differs from 100), and raw number began to rose, the HDD's heads will be broken down in nearly time . Before failure happens, hard disk device could sometimes freeze and make a soft knocking sound.
If Selfscan test is launched - hdd with such problem will halt on N4-SvVfy or on offtrack read-write test.If mentioned in advance - it is possible to save all imortant data in a save place.
Thus sometimes SMART gave us a useful information. It didn't forecast anything useful for a long time so people stopped to believe it. :) But in this case - attribute N195 could certainly tell us how long this device would live.
Vadim
Postby Vadim » 03.02.08, 18:47
I want to add. This is information is the truth also for Quaxtor HDDs (Quantum-Maxtor drives) :D
Best regards, Vadim Morozov
ACE Laboratory technical director
Re: SMART at Quantum HDD
Postby AJ2008 » 05.01.09, 18:29
Yuriy Manjilevskiy wrote:It was repeatedly noticed that SMART attribute N195(Hardware ECC Recovered) on last Quantum models(including Quantum-Maxtor models) reflects the condition of heads. If its number rapidly began to fall(noticeably differs from 100), and raw number began to rose, the HDD's heads will be broken down in nearly time . Before failure happens, hard disk device could sometimes freeze and make a soft knocking sound.
I thought Selfscan will lose user data?
steven
Postby steven » 16.04.09, 12:39
Nice. Info,..
But now. no much quantum I can see to recover
GURU
Postby GURU » 01.05.09, 09:47
on Maxtor drives 195 or 0xc3 means "on the fly error rate" so I guess it would show a degrading head as the error rates corrected will increase over time
dobrevjetser
Postby dobrevjetser » 01.04.10, 13:04
Well, i could use this info for the just received Quaxtor drive :)
Dobre
Return to “Quantum”
