DiamondMax 9- Read sectors only in "Active Utility"
Posted: 26.03.18, 11:07
Hello Guys,
I’m handling this drive. It spin up with no clicking or other noise, and get DRDY DSC.
I checked the SA and attached the report. In “Hdd configuration changing” I disabled all the auto reallocation operations and wrote them in the SA.
I tried to read some sectors with "sector edit" within the utility but I get ABRT error. Then I read the sectors via "active utility" and the reading was successful.
So in DE I scanned the MFT map from “active utility” but the reading was very very slow.
I was able to map the sectors used by bitmaps. The sectors used are around 80GB. Reading in active utility is very slow, even very very slow, it will take 13 days.
Is there anything else I can try to speed up the reading?
Thanks for any hint or help
Jojo
Jojo
- Log.log
- (97.16 KiB) Downloaded 439 times
