Problem with Maxtor 6L080L0 Calipso family
Posted: 07.05.10, 15:57
Hi to all.
I connect this Hdd to Pc3K and i perform SA chk
I see module 78, 18 and 1B was bad
I try to rewrite it and regen translator using good module 33, but the process end with error
I try to make a SA Surface analisys with remap option enabled ( i try this more times ) but that not solve the problem
I try to use Autorecovery procedure, but that not solve the problem too.
Some one can tell me how i can remap bad sector from SA ?
May be if i can remap bad sector in SA i can write it and try to restore bad module.
Any help is welcomed.
Thank you to all
Thank you to all
