Maxtor SABRE
Posted: 09.11.09, 12:57
by Bruno
Dear all
I have here a Sabre Drive 30GB. Its from Lacie (RAID0) with two drives. the client says he powered off the drive before unmounting form PC.
One Drive is ok, but the second makes trouble.
Firs,t i save all Modules.
On any Modules i corrected checksum.
SA Surface verification:
Zone Id ................................... 6
Start UBA ............................ 19 008
Size ................................. 2 400
20 736 .................................... UBA 20736 (3) reading error. Techno cmd error. Cmd : 53. Code : 0016 C/H/S : 104505/3/0
20 737 .................................... UBA 20736 (3) reading error. Techno cmd error. Cmd : 53. Code : 0016 C/H/S : 104505/3/0
20 738 .................................... UBA 20736 (3) reading error. Techno cmd error. Cmd : 53. Code : 0016 C/H/S : 104505/3/0
Errors .................................... 3
SA Structure Test all ok without this:
Checking RZTbl-PList
Difference ................................ not found
Checking RZTbl-HList
Beg.Cyl. End Cyl. :Def.count Def.count (PList)
1082 1214 :73 1987
1348 1480 :1 41
1481 1613 :0 4
1747 1879 :3 78
1880 2012 :0 4
2146 2278 :0 1
2545 2677 :0 1
2678 2810 :0 1
102138 102389 :0 2
102390 102641 :0 1
102642 102893 :0 6
102894 103145 :0 5
103146 103397 :0 8
103398 103649 :0 1
103650 103901 :1 6
103902 104153 :0 5
104154 104405 :0 10
In DE i could only read the sector "0".
All other Sectors makes error.
Now i deleted G-List and making translator regen. ok.
No read other sectors the the "0"
delete P-List and regen Translator, ok
What i have overlookt?
Thanks for any help.
Bruno
Re: Maxtor SABRE
Posted: 11.11.09, 04:42
by steven
Do u sure it is SaABRE 30 gb ONLY. Never see Sabre Drive with only 30 GB.
pls post more detail of SA Structure test
Re: Maxtor SABRE
Posted: 11.11.09, 16:32
by Bruno
Dear Steven
Thank you for your engagement.
Be shure that is a SABRE, but i forgot a "0" (300GB);-(
Here is the complete Structure Test:
SA structure test
Selected family ........................... SABRE
Model ..................................... Maxtor 6L300R0
Firmware .................................. BAH41G10
Serial .................................... L60H8MHG
Min. cylinder ............................. 1082
Max. cylinder ............................. 104431
Checking UList
Id ........................................ 37
Read ...................................... Yes
Header .................................... U_LIST00
Checksum .................................. Ok
The number of SA defects .................. No
P-List size ............................... 11
HDD configuration module
Id ........................................ 1F
Header .................................... DISK
Serial number ............................. L60H8MHG
Max LBA ................................... 586114704
Head number ............................... 6
Head map .................................. 0 1 2 3 4 5
SA head map ............................... 0 1 2 3 4 5
Model1 ............................... Maxtor 6L320R0
Max LBA .............................. 632672208
Model2 ............................... Maxtor 6L320R0
Max LBA .............................. 625142448
Model3 ............................... Maxtor 6L300R0
Max LBA .............................. 586114704
Model4 ............................... Maxtor 6L250R0
Max LBA .............................. 490234752
Checking Calibration adaptives
Id ........................................ 1E
Header .................................... SRV8rü
Checking User data adaptives
Header .................................... CR0Tn¨
Checking Zone Table
# : Start Cyl: End Cyl: SPT
1 : 1082: 7567: 1312
2 : 7568: 14052: 1280
3 : 14053: 20537: 1248
4 : 20538: 27022: 1228
5 : 27023: 33507: 1190
6 : 33508: 39992: 1152
7 : 39993: 46477: 1120
8 : 46478: 52962: 1088
9 : 52963: 59447: 1036
10 : 59448: 65932: 998
11 : 65933: 72417: 960
12 : 72418: 78902: 896
13 : 78903: 85387: 850
14 : 85388: 91872: 800
15 : 91873: 98357: 740
16 : 98358: 104431: 691
17 : 104451: 104744: 384
Checking DMCS
Id ........................................ 1D
Header .................................... Ok
HUTL Start UBA ............................ 6874
HUTL Rec Count ............................ 0
HUTL Length ............................... 32
HUSR Start UBA ............................ 6906
USR Rec Count ............................. 2155
HUSR Blk Count ............................ 8
HUSR Total Sectors ........................ 0
HUST Blk Len .............................. 16
Checking ROM Copy
Check sum Value ........................... 928B
Checking ATA overlays
Header1 ................................... MO
Header2 ................................... 0000
OverlayId ................................. 0003
ROM CRC ................................... Ok
OverlayId ................................. 0004
OverlayId ................................. 0005
OverlayId ................................. 0006
OverlayId ................................. 0007
Checking Techno mode overlays
Header2 ................................... 00..
OverlayId ................................. 0008
OverlayId ................................. 0009
OverlayId ................................. 000A
OverlayId ................................. 000B
OverlayId ................................. 000C
OverlayId ................................. 000D
OverlayId ................................. 000E
OverlayId ................................. 000F
OverlayId ................................. 0010
OverlayId ................................. 0011
OverlayId ................................. 0012
OverlayId ................................. 0013
OverlayId ................................. 0014
OverlayId ................................. 0015
OverlayId ................................. 0016
OverlayId ................................. 0017
OverlayId ................................. 0018
OverlayId ................................. 0019
OverlayId ................................. 001A
OverlayId ................................. 001B
OverlayId ................................. 001C
OverlayId ................................. 001D
OverlayId ................................. 001E
OverlayId ................................. 001F
OverlayId ................................. 0020
OverlayId ................................. 0021
OverlayId ................................. 0022
OverlayId ................................. 0023
OverlayId ................................. 0024
OverlayId ................................. 0025
OverlayId ................................. 0026
OverlayId ................................. 0027
OverlayId ................................. 0028
OverlayId ................................. 0029
OverlayId ................................. 002A
OverlayId ................................. 002B
OverlayId ................................. 002C
Checking RZTbl
Checking P-List
Checking G-List
Checking G-List copy
1082 1214 :73 1987
1348 1480 :1 41
1481 1613 :0 4
1747 1879 :3 78
1880 2012 :0 4
2146 2278 :0 1
2545 2677 :0 1
2678 2810 :0 1
102138 102389 :0 2
102390 102641 :0 1
102642 102893 :0 6
102894 103145 :0 5
103146 103397 :0 8
103398 103649 :0 1
103650 103901 :1 6
103902 104153 :0 5
104154 104405 :0 10
Checking HLists
Block0
Header .................................... UHRS0000
Defect Count .............................. 78
Block1
Header .................................... UHRS0010
Defect Count .............................. 400
Block2
Header .................................... UHRS0020
Block3
Header .................................... UHRS0030
Block4
Header .................................... UHRS0040
Block5
Header .................................... UHRS0050
Block6
Header .................................... UHRS0060
Block7
Header .................................... UHRS0070
Defect Count .............................. 37
Checking security
Header .................................... SECU
User Password ............................. "********************************"
Master Password ........................... "Maxtor*INIT SECURITY TEST STEP*F"
User password setup ....................... No
Master code ............................... FFFE
Security level ............................ HIGH
Checking S.M.A.R.T.
[SMRT_T] .................................. Ok
[SMRT_A] .................................. Ok
[SMRT_AC] ................................. Error
[SMART_SUMMAR] ............................ Ok
[SMART_ST] ................................ Ok
[SMART_HOSTV] ............................. Ok
Checking FMTI
Id ........................................ 93
UBA : ID : Size : Module : Importance : Read : Header : CS
0 : FF : 4 : [RCT0] : As : Yes : Ok : Ok
4 : 37 : 1 : U_LIST : Ad : Yes : Ok : Ok
8 : 1F : 1 : DISK : B : Yes : Ok : Ok
9 : 78 : 32 : RZTBL : Ad : Yes : Ok : Ok
41 : 18 : 313 : AT_PDL : Ad : Yes : Ok : Ok
354 : 21 : 11 : RCTF : As : Yes : Ok : Ok
398 : 1E : 2 : SRV : As : Yes : Ok : Ok
402 : 1A : 1 : SECU : C : Yes : Ok : Ok
403 : 2F : 1 : [SMRT_T] : C : Yes : Ok : Ok
404 : 30 : 1 : [SMRT_A] : C : Yes : Ok : Ok
405 : 63 : 1 : [SMRT_AC] : C : Yes : Ok : Ok
420 : 22 : 1 : ATAF : B : Yes : Ok : Ok
424 : 34 : 256 : ARREH : Dr : Yes : Ok : Ok
680 : 48 : 1 : [LABEL] : Dr : Yes : Ok : Ok
681 : 1D : 2 : DMCS : C : Yes : Ok : Ok
683 : 1B : 50 : AT_POL : C : Yes : Ok : Ok
736 : 64 : 1 : MAXATG : B : Yes : Ok : Ok
760 : 5E : 273 : EVTLG : Dr : Yes : Ok : Ok
1 083 : 93 : 128 : FMTI : Ad : Yes : Ok : Ok
1 033 : 70 : 1 : [SMART_SUMMAR] : Dr : Yes : Ok : Ok
1 034 : 71 : 1 : [SMART_ST] : Dr : Yes : Ok : Ok
1 035 : 72 : 32 : [SMART_HOSTV] : Dr : Yes : Ok : Ok
1 075 : 7B : 8 : FW : Dr : Yes : Ok : Ok
2 408 : 39 : 256 : [ROM SA] : B : Yes : Ok : Ok
2 664 : 38 : 160 : [OVL ATA] : B : Yes : Ok : Ok
2 824 : 4F : 1792 : [OVL Tech] : B : Yes : Ok : Ok
6 824 : A7 : 50 : AT_POL (Copy) : C : Yes : Ok : Ok
6 874 : 33 : 2048 : [HUTL/HUSR] : Dd : Yes : Ok : Ok
Do you have an idee about the malfunction of tids drive.
He start normal become ready, but i can only read the sector "0"...
Thanks for your Help.
Bruno
Re: Maxtor SABRE
Posted: 12.11.09, 10:50
by steven
1082 1214 :73 1987
1348 1480 :1 41
1481 1613 :0 4
1747 1879 :3 78
1880 2012 :0 4
2146 2278 :0 1
2545 2677 :0 1
2678 2810 :0 1
102138 102389 :0 2
102390 102641 :0 1
102642 102893 :0 6
102894 103145 :0 5
103146 103397 :0 8
103398 103649 :0 1
103650 103901 :1 6
103902 104153 :0 5
104154 104405 :0 10
RZTBL a serious problem for DR. Actually this can be fixed with translator regen ( s/w or H/w ) But I hope u save ALL track before do any modification..
Re: Maxtor SABRE
Posted: 06.12.09, 18:29
by Bruno
Dear Steven
I'm make translator regen SW and after no access to HD translator regen HW.
The translator regen end successful, boot time, but i have only access to sector "0" and "63" :? . Now i write all modules (from first save) back to the surface. All modules could be written succesfull.
I think a module is not ok, because the user disconnect the plug from wall, without logout the LACIE hd, but witch module could be defekt?.
In DE i could be read the first sector and sect.63 ok (green). i take a test red with read ignore CRC. Now sect 2 is black, the next 15 are grey, next black and so on. 63 is green.
Is there a way to get the te data??
Thanks for help.
Bruno
Re: Maxtor SABRE
Posted: 11.12.09, 00:56
by N.C.
It is hard to help you remotely, but i can recover any (original) maxtor in any case if recoverable at all.
For this case, i am sure, i can do it for you, if you interested.
Janos
