Data written with offset : -336
Posted: 18.02.09, 11:02
Hi ,
There is a problem with Maxotr 4D040H2 , It loaded by LDR , I can not access user data , I afraid to do SA Surface Verification , please see below:
SA Writing Test:
Applying SRV
SA writing test
Data writing
Data reading
Check-up of previous data
Data have been written with offset : -336
SUMMARY of SA structure test
HDD Modules have reading errors.
Modules | Comment
FF | SA adaptive data module is damaged.
1D | Translator modules are defective. For restoration it should be
| performed:
| 1) To perform SA surface checking with the option of restoration BAD
| blocks via writing
| 2) To clear P and G-List
| 3) To restart HDD in normal mode
| 4) To perform translator regeneration
48,64,5E,93 | HDD has non critical damages and can work correctly.
What is solution of like this problem for Recovery ?
Thank you
SA Writing Test:
Applying SRV
SA writing test
Data writing
Data reading
Modules | Comment
| performed:
| blocks via writing
Thank you
