Repair of Draco series??
Posted: 04.12.08, 00:55
by Balvan
I have a 54098U8 that is not supported with the PC-3000. It boots but does not read S/N and I cannot access LBAs.
Auto recovery does not work.
I cannot boot from internal drive program.
I cannot read any modules.
I cannot create a loader.
Is there anything I can do to recover this drive?
Thank you.
Re: Repair of Draco series??
Posted: 17.12.08, 09:29
by dmarques
Does the drive reach ready?
What does it show on firmware version?
Posted: 22.12.08, 06:10
by Balvan
First of all, the PC3000 UDMA won't read the firmware of the drive, so a PC3000 IDE model was used.
The drive comes ready. The PC3000 identifies the bad drive as a Draco (the same way that it identifies Maxtors with corrupted firmware by generic family name). The PC3000 gives the passport info on other good Draco drives.
When attempting to create a loader with the bad drive, it errors out or I get State"SH=0" in the bar.
When I try to make loaders from other good Draco drives, I only get errors.
What can I do?
Posted: 01.05.09, 09:51
by GURU
I would hot-swap this drive :O) And then just check SA if you really want to repair that drive.
Posted: 01.05.09, 11:08
by steven
if you have DONOR try Hotswap. and check SA
