Maxtor 6E040L0 module 18 and 78 errors
Posted: 11.05.08, 05:39
by Nova
Hi guys
Need help on Maxtor 6E040L0510, it has module 18 (UBA 41) error and also Module 78, I tried regenerate but didnt work.
I can switch the drive to ALT-SA all modules are ok, and can I rewrite module 18 and 78 from ALT-SA to the faulty module 18 and 78?
Thank you for any help.
Posted: 12.05.08, 10:09
by Alex Ivlev
You need tests->Service information->Work with service area->SA structure test, and send it to ts2@acelab.ru. What have you done with this drive?
Re: Maxtor 6E040L0 module 18 and 78 errors
Posted: 05.01.09, 10:45
I disagree. I think that module 18 and 78 will be repaired if you run tests->Service information->Work with service area->SA Surface Verification.
Then select Module Recovery from SA menu to repair PLIST (18). Then set to Master, disk should ID ok then run Translator Regeneration.
Posted: 07.01.09, 02:44
by Pepe
Alt SA (SA C) mod 18 and 78 are not appropriate for SA A.
If the drive can write its SA correctly (SA write test passes), U can try rewriting these modules to get rid of the reading error, then regenerate the translator.
if it doesn't work, I mostly use smart hotswap.
pepe
Posted: 07.01.09, 10:27
Nova wrote:Hi guys
Seems that the fault is with main SA not Alt-SA.
If SA Surface Verification fails, and modules cannot be written as pepe suggests, then HotSwap will be only way to get data back
Posted: 29.06.12, 14:59
by Nadpc3k
i have the same problem ... for hot swap which module i need from the patient drive... all of them or some slected one ?
