dear guru accept my regards
nowadays I am involved with a H.D.D in the following specification :
6Y080l0422611 , YAR41BW0
when i just connet it to power supply , after spinning up it makes a strange sound but obviously it is not head click , something like this : DEEEED , DEEEEED .... .
what kind of proble do you guess it has ?
thank you in advance
Mojtaba Morady
Maxtor 80 GB after spinning up has starnge sound Topic is solved
- mojimorady
- New user
Mojtaba Morady
Data Recovery Expert
Data Recovery Eng. at CSSI
Re: Maxtor 80 GB after spinning up has starnge sound Topic is solved
Hello!
What a LEDs are lighting?
Is it ready to work after power supply?
What a log in PC3000?
does the motor spin? Usually on these cases with bad motor it makes musical beeping sound, otherwise you should make sure PCB is 100% good, maybe test it on donor HDD
