Newbie - Faulty MHW2160BH PL
Posted: 13.12.14, 17:56
by Martin281
Hi everyone,
I am absolute newbie in the work with PC3000 and try to repair faulty Fujitsu MHW2160BH PL drive (I don“t care about the data, just for later using). I ran the SA structure test and here is the report:
Selected family......................... : MHW2xxxBH
Selected model.......................... : MHWxxxxBH
Model by HDD ID......................... : FUJITSU MHW2160BH PL
Firewall state: 0
Unlocking...
Firewall state: 2
Tech command set: SATA cmd set
Reading module table from SA...
Module table is loaded
Loading : HS, head map module......................................... : Ok
Loading : PL, single sector defect list and zone allocation table module : Error
Error................................................................. : PL: Invalid zones distribution info (ZoneNo)!
Test : View ROM information
ROMInfo reading......................... : Error
Error reading ROM parameters : Rom_Info : information from ROM not loaded (Error reading HDD memory)
Test : SA structure test
LOADING MODULES
Module 10004.......................................................... : Ok
Module 10020.......................................................... : Ok
Module 10006.......................................................... : Ok
Module 10022.......................................................... : Ok
Module 100E1.......................................................... : Ok
Can`t read module 1003D from HDD
Module 1003D.......................................................... : Error
Can`t read module 1003E from HDD
Module 1003E.......................................................... : Error
Can`t read module 1003F from HDD
Module 1003F.......................................................... : Error
Can`t read module 10040 from HDD
Module 10040.......................................................... : Error
Can`t read module 1005A from HDD
Module 1005A.......................................................... : Error
Can`t read module 1005B from HDD
Module 1005B.......................................................... : Error
Module 10001.......................................................... : Ok
Can`t read module 100E8 from HDD
Module 100E8.......................................................... : Error
Module 10007.......................................................... : Ok
Module 100E2.......................................................... : Ok
Module 10008.......................................................... : Ok
Can`t read module 1000C from HDD
Module 1000C.......................................................... : Error
Can`t read module 1000D from HDD
Module 1000D.......................................................... : Error
Module 1000A.......................................................... : Ok
Module 1002D.......................................................... : Ok
Module 1002B.......................................................... : Ok
Module 1002A.......................................................... : Ok
Module 10009.......................................................... : Ok
Module 10031.......................................................... : Ok
Module 10027.......................................................... : Ok
Module 10032.......................................................... : Ok
Module 10028.......................................................... : Ok
Module 10045.......................................................... : Ok
Module 10070.......................................................... : Ok
Module 10029.......................................................... : Ok
Module 10037.......................................................... : Ok
Module 100E9.......................................................... : Ok
Module 100EA.......................................................... : Ok
Can`t read module 100ED from HDD
Module 100ED.......................................................... : Error
Module 1006C.......................................................... : Ok
Can`t read module 10050 from HDD
Module 10050.......................................................... : Error
Can`t read module 10055 from HDD
Module 10055.......................................................... : Error
Can`t read module 10054 from HDD
Module 10054.......................................................... : Error
Module 10051.......................................................... : Ok
Module 10052.......................................................... : Ok
Can`t read module 10057 from HDD
Module 10057.......................................................... : Error
Can`t read module 10058 from HDD
Module 10058.......................................................... : Error
Module 10002.......................................................... : Ok
Module 1000B.......................................................... : Ok
Module 10005.......................................................... : Ok
Module 1000E.......................................................... : Ok
Module 10030.......................................................... : Ok
Module 10035.......................................................... : Ok
Module 10036.......................................................... : Ok
Module 1002E.......................................................... : Ok
Module 10041.......................................................... : Ok
Module 10042.......................................................... : Ok
Module 100A0.......................................................... : Ok
Module 10003.......................................................... : Ok
Module 100E3.......................................................... : Ok
Module 100A9.......................................................... : Ok
Module 100AA.......................................................... : Ok
Module 100AB.......................................................... : Ok
Module 100AC.......................................................... : Ok
Module 100AD.......................................................... : Ok
Module 10023.......................................................... : Ok
Drive not ready
Module 100FA.......................................................... : Error
Module 100EE.......................................................... : Ok
Module 100D0.......................................................... : Ok
Module 100D1.......................................................... : Ok
Module 100D8.......................................................... : Ok
Module 100D9.......................................................... : Ok
Module 100DA.......................................................... : Ok
Module 100DB.......................................................... : Ok
Module 100DC.......................................................... : Ok
Module 100DD.......................................................... : Ok
Module 100DE.......................................................... : Ok
Module 100DF.......................................................... : Ok
Module 100E4.......................................................... : Ok
Module 100E5.......................................................... : Ok
Module 100E6.......................................................... : Ok
Module 100E7.......................................................... : Ok
Module 10056.......................................................... : Ok
Module 10010.......................................................... : Ok
Module 10011.......................................................... : Ok
Module 10012.......................................................... : Ok
Module 10013.......................................................... : Ok
Module 10014.......................................................... : Ok
Module 10016.......................................................... : Ok
Module 10017.......................................................... : Ok
Module 10018.......................................................... : Ok
Module 10019.......................................................... : Ok
Module 1001E.......................................................... : Ok
Module 10066.......................................................... : Ok
Module 10067.......................................................... : Ok
Module 10068.......................................................... : Ok
Module 1006B.......................................................... : Ok
Module 1006D.......................................................... : Ok
Module 1001C.......................................................... : Ok
Module 1001F.......................................................... : Ok
Module 10021.......................................................... : Ok
Module 10060.......................................................... : Ok
Module 10061.......................................................... : Ok
Module 10062.......................................................... : Ok
Module 10063.......................................................... : Ok
Module 10064.......................................................... : Ok
Module 10065.......................................................... : Ok
Module 100A1.......................................................... : Ok
Module 100A2.......................................................... : Ok
Module 10080.......................................................... : Ok
Module 100C0.......................................................... : Ok
Module 1003A.......................................................... : Ok
Module 1001D.......................................................... : Ok
Module 10069.......................................................... : Ok
Module 1006A.......................................................... : Ok
Module 10015.......................................................... : Ok
Module 1006F.......................................................... : Ok
Can`t read module 100EB from HDD
Module 100EB.......................................................... : Error
Module 10078.......................................................... : Ok
Module 10079.......................................................... : Ok
Module 1007A.......................................................... : Ok
Module 1007B.......................................................... : Ok
Can`t read module 1007C from HDD
Module 1007C.......................................................... : Error
Can`t read module 1007D from HDD
Module 1007D.......................................................... : Error
Can`t read module 1007E from HDD
Module 1007E.......................................................... : Error
Can`t read module 1007F from HDD
Module 1007F.......................................................... : Error
Module 100B8.......................................................... : Ok
Module 100B0.......................................................... : Ok
Module 100B1.......................................................... : Ok
Module 100B2.......................................................... : Ok
Module 100B3.......................................................... : Ok
Can`t read module 100B4 from HDD
Module 100B4.......................................................... : Error
Can`t read module 100B5 from HDD
Module 100B5.......................................................... : Error
Can`t read module 100B6 from HDD
Module 100B6.......................................................... : Error
Can`t read module 100B7 from HDD
Module 100B7.......................................................... : Error
As far I have read the manual for Fujitsu drives..there is faulty overlay mode module (1003D, 1003E), so the drive is inaccesible and ROM cannot be read too. How can I access the modules in the drive ROM to write them to SA? There are absolutely no resource module files for this drive in the PC3000 database. What am I supposed to do?
Thanks.
Martin
Re: Newbie - Faulty MHW2160BH PL
Posted: 17.07.15, 14:43
by Maxim_TS
Hello Martin,
Since we see ROM reading errors in log, most possibly the drive has a problems with PCB or ROM data.
In this case the repairing of drive is not possible.
