Sorry to ask a rudimentary question; however, I have been away for 5 months.
I have a drive that is making a clicking sound. Hooking it up to the PC3000, in the Utility mode I receive the following response.
Selected family......................... : MHV2xxxAT/AH
Selected model.......................... : MHV2100AT
Model by HDD ID......................... :
Reading module table from SA...
SA module table isunreadable!
Loading : HS, head map module......................................... : Error
Error................................................................. : Can`t read module 0104 from HDD
Loading : PL, single sector defect list and zone allocation table modu : Error
Error................................................................. : Can`t read module 0102 from HDD
The DRD DSC are blue ERR ABR are Red
I have a donor drive; however when I swapped the PCB I received the following error
I then took the Original PCB and placed it on the donor drive and the drive spun up and was functional.
When I try to read the ROM I receive the following message
Test : Reading ROM
Reading ROM to file ( Z:\PC3000\!Profiles\!Profiles\FUJ25\MHV\FUJITSU MHV2100AH-000000A0-NT60T6A27RNV\Data\ROM\ROM.bin )
Error reading ROM
At this point, would I be correct to say that I have to replace the heads?
Thanks for any input
Frank
mhv2100AH Question
- Towerrat79
mhv2100AH Question
Frank Meincke
Gefund-IT (Datenrettung)
Daimlerstrasse 70
74545 Michelfeld
tel: 0791-94 66 68 52
email: Info@Gefund-IT.de
web: www.Gefund-IT.de
Daimlerstrasse 70
74545 Michelfeld
Re: mhv2100AH Question
Yes by the "syntomphs" could be MHA, u should check the MR sensor´s to tried to diagnostic if heads are Ok, or no that is only one way ,
clicking in Fujitsu mean head was damaged. you need to change head. this series have 4 head. and I hope nothing going bad in platter.
clicking mean head problem in Fujitsu drive.. You need to change head to save its data. and off course I hope nothing going bad in platter
Good luck
Good luck
- Towerrat79
Alberto wrote:Yes by the "syntomphs" could be MHA, u should check the MR sensor´s to tried to diagnostic if heads are Ok, or no that is only one way ,
Alberto and Steven
Thank you for your replies.
Alberto,
I do not understand what you meant when you stated "should check the MR sensor´"
What is the MR Sensor and what is the 180 signify?
Frank
Frank Meincke
Daimlerstrasse 70
74545 Michelfeld
Daimlerstrasse 70
74545 Michelfeld
MR Magneto Resistive Sensor part of the Read/Write Element´s (MHA) , 180 was a word changed after i post it each time i wrote the word " sensor on plural
