MHV2080AH Password
Posted: 16.01.09, 09:51
by Mike_Montgomery
Is there a way of unlocking PW protected MHVxxAH drives?
When running the unlock password wizard I get a message saying SU us not writable an that I should use terminal to remove the password - I dont know the jumper settings for the adapter.. Does anyone know this info ?
Mike
Re: MHV2080AH Password
Posted: 03.04.09, 12:47
by STT
Mike
That's a very good question I have the same problem. On the previous PC3K I used the Hitachi jumper settings successfully but for the UDMA this is not the solution. Did you resolve this?
Derek
Posted: 03.04.09, 12:52
You should have a MHV terminal adaptor with your PC3000 for removal of password, it attaches to PCB and should be a simple procedure, unless I am misunderstanding the problem.
Posted: 03.04.09, 13:04
by Mike_Montgomery
I ordered the Terminal adapter from Acelab as my UDMA and all is well
THanks,
Mike
Posted: 04.04.09, 05:39
by steven
and now can be done to MHW and MHX
Posted: 06.05.09, 10:35
by mvg
I have PC3K UDMA and the new Fujitsu terminal connector. Though there was no documentation regarding the terminal connector to PCB connections, I tried and it it worked swiftly with MHV2080BH
Regards,
Mathew
Posted: 10.05.09, 20:49
by aviko
If you havent adapter you can use seagate sata adapter and 2 goldpins. (TX and RX is enough). just look at pcb there are 4 holes for connector, put these goldpins there and look on seagate sata adapter where TX RX traces go. This is all you need. Tommorow ill take a picture for adapter placement.
Here it is
- on this photo its MHW2160BJ
- terminal_fujitsu.jpg (68.39 KiB) Viewed 23069 times
Posted: 13.05.09, 04:31
by steven
Thanks for the trick
Posted: 25.05.09, 19:20
Thinking outside the box, I like this
Posted: 10.08.12, 12:12
by avenger-fr
An other way (for MHV2100AH IDE)
- 25140 013_crop.jpg (104.03 KiB) Viewed 22615 times
Posted: 06.10.15, 20:47
by cuumaytinh
it not work . I'm try and wait 60 min . nothing change
