MPG3102AT's HDD ID couldn't be read Topic is solved
Posted: 13.08.07, 14:40
Sometimes happens that HDD ID couldn't be read, at the same time an error on module 170 is reported.
At this case we have to rewrite that module from any FUJITSU drive and this problem is solved.
Also we could create this module by ourself at Hex editor, as there are nothing except zeros inside that module,
the only thing you should have the same size as original module is.
