Model MPC3043AT shows 9GB
I have HDD Model MPC3043AT. It shows 9.08 GB and model MPC3032AT in log. Please provide solution for recovery of data.
Re: Model MPC3043AT shows 9GB
Selected family......................... : MPC3xxxAT
Selected model.......................... : MPC3032AT
Model by HDD ID......................... : FUJITSU MPC3032AT
ROMInfo reading......................... : Ok
DB contains no information about this FW
Reading ROM
Search for module table by signature.... : Ok
Search for zone allocation table by sign : Ok
Modules table found in ROM at address 0x12A1.
Zone allocation table found in ROM at address 0x431.
Information will be saved to supported FW DB.
Open the options editing dialog to check and save it
Zone allocation table (ROM)............. : Initializing from ROM
Loading : HS, head map module......................................... : Error
Error................................................................. : Can`t read module 0104 from HDD
Reading ROM
I think first of all you should read a bit more on the use of pc3000.
Also, you should contact support to get help like that.
Or else outsource your job and try with non client drives.
Do SA modules read ok? For a HDD this old I would probably go for hotswap on it.
