Fujitsu MHZ2320BH unlocking?
krager
Postby krager » 23.07.13, 19:40
Is unlocking this drive supported by PC-3000 UDMA? If so, can you explain the process please?
krager
Re: Fujitsu MHZ2320BH unlocking?
Postby krager » 24.07.13, 20:24
ACE Support provided the solution. Using the USB Terminal with special Fujitsu adapter and the MHY2...procedure.
Selected the MHY2.../BH procedure from the menu after utility launch and clicked the "Password Clearing" button.
Drive was successfully unlocked.
Thanks ACE!
Return to “Fujitsu”
