Toshiba MK5072GSX scratched Surface
Posted: 03.10.18, 21:18
by d1d
I have a Toshiba 2,5" HDD whit a scratched Surface in the Center of the disk. The HDD is clicking. I have just changed the head but always the same problem. I can see the rom and ram about the com port, but i can't get the data. What i have to do?
Thanks a Lot!
Best wishes Luigi
Re: Toshiba MK5072GSX scratched Surface
Posted: 04.10.18, 14:15
Most likely just give up and move on.
Posted: 06.10.18, 10:41
by d1d
Also when the Surface is scratched only in the middle...?
See the pics...
- Surface
- 20181003_160125.jpg (272.58 KiB) Viewed 15813 times
- HDD Cover
- 20181003_152357.jpg (8.81 KiB) Viewed 15813 times
Posted: 08.10.18, 08:58
top surface is surface '0' and as far as I am aware you need this surface to be OK to initialize it. As most SA is stored in PCB, maybe you can place patient PCB on donor to init donor PCB, then hotswap it to your patient and try reading? Not sure this will work though but I do not think you have many options available...
Posted: 08.10.18, 13:20
by Tawfeek
AJ2008 wrote:Source of the post top surface is surface '0' and as far as I am aware you need this surface to be OK to initialize it. As most SA is stored in PCB, maybe you can place patient PCB on donor to init donor PCB, then hotswap it to your patient and try reading? Not sure this will work though but I do not think you have many options available...
i thought the button head is the 0
Posted: 09.10.18, 15:04
by Sergey_TS
Tawfeek, Head0 is on the top here as was correctly mentioned above
AJ2008, but what about original P-list (DD)...?
Posted: 09.10.18, 17:16
by Tawfeek
Sergey_TS wrote:Source of the post Tawfeek, Head0 is on the top here as was correctly mentioned above
Is head 0 on the top in all HDD kinds or just in Toshiba ?
Posted: 10.10.18, 11:18
I agree this is a problem...
