Toshiba MQ01ABD100H Problem
Posted: 10.05.18, 08:39
Model: Toshiba MQ01ABD100H
2.5", 4K sector
FW: ALF07M
Starts normal with full ID and correct size. No noise or slow detection.
Could access service information and backup them.
Problem is: any attempt to read user data returns AMN/INF error and makes the drive busy.
Tried Solution: Reading Options/ Use utility, Consider logical sector per physical sector, PBA access (Solve G-list damage)
ends with error
clearing G-list also didn't help
Terminal output shows the following error:
SIGNATURE SCAN FAILED
HDD FATAL ERROR
I guess the problem should be related to onboard NAND flash corruption but don't know how to deal with
Any hint or help to solve the problem is highly appreciated
Thank you
2.5", 4K sector
FW: ALF07M
ends with error
HDD FATAL ERROR
Thank you
