Toshiba MQ01ABD100H Problem Topic is solved
PC3K_USER
Postby PC3K_USER » 10.05.18, 08:39
Model: Toshiba MQ01ABD100H
2.5", 4K sector
FW: ALF07M
Starts normal with full ID and correct size. No noise or slow detection.
Could access service information and backup them.
Problem is: any attempt to read user data returns AMN/INF error and makes the drive busy.
Tried Solution: Reading Options/ Use utility, Consider logical sector per physical sector, PBA access (Solve G-list damage)
ends with error
clearing G-list also didn't help
Terminal output shows the following error:
SIGNATURE SCAN FAILED
HDD FATAL ERROR
I guess the problem should be related to onboard NAND flash corruption but don't know how to deal with
Any hint or help to solve the problem is highly appreciated
Thank you
Re: Toshiba MQ01ABD100 Problem
Postby AJ2008 » 10.05.18, 18:31
Model is MQ01ABD100 or MQ01ABD100H?
PC3K_USER
Re: Toshiba MQ01ABD100H Problem
Postby PC3K_USER » 11.05.18, 04:53
Sorry, Its MQ01ABD100H (Corrected)
PC3K_USER
Postby PC3K_USER » 11.05.18, 08:36
power up terminal output of a working model:
START REBUILD COMPLETE
msurgeon
Postby msurgeon » 18.05.18, 16:16
PC3K_USER
Postby PC3K_USER » 21.05.18, 09:24
Hi Msurgeon
Thanks for reply.
I already am aware of this solution. Problem is, my PC3K Express is version 5.9.21 and there is no such menu item as "Flash Permanent cache ON/OFF", only SMART and ECC.
Wondering if there is any other method to turn OFF the Flash, like terminal commands ,etc...
Re: Toshiba MQ01ABD100H Problem  Topic is solved
Postby AJ2008 » 21.05.18, 10:21
with a terminal connection, send command 'nva' and restart drive
Postby DataMedics » 21.05.18, 15:49
AJ2008 wrote:Source of the post with a terminal connection, send command 'nva' and restart drive
So nva is the terminal command to disable the SSD side? Good to know. Unnecessary if you've got PC-3000, but might be helpful if you're helping someone who's only got a toy like MRT or Dolphin.
LarrySabo
Postby LarrySabo » 21.05.18, 16:31
DataMedics wrote:Source of the post might be helpful if you're helping someone who's only got a toy like MRT or Dolphin.
:evil:
Postby DataMedics » 21.05.18, 16:42
LarrySabo wrote:Source of the post
:evil:
hehe, sorry Larry.
When are you going to finally break down and just buy a PC-3000? You've probably paid the price of one already in all those other tools you've got. Just wait until you get behind the wheel of that Cadillac of a tool. :D
LarrySabo
Postby LarrySabo » 21.05.18, 17:46
DataMedics wrote:Source of the post hehe, sorry Larry.
No problem, Jared. I missed my chance with the 25% discount on Ace's 25th anniversary; I'll just have to wait for a 50% discount on their 50th. LOL
PC3K_USER
Postby PC3K_USER » 22.05.18, 03:38
Thank you so much AJ2008
Problem solved.
1. Sent nva vial terminal
2. Restart the drive
3. Tried to read sector... Error
4. Tried Reading Options/ Use utility, Consider logical sector per physical sector, PBA access (Solve G-list damage)...finished without error :D :D :D
5. Refresh, read sector OK :)
6. Started cloning
Return to “Toshiba native”
