TOSHIBA MQ01ABD050
Posted: 27.06.17, 11:48
Hi all,
i have here a strange case with a TOSHIBA MQ01ABD050.
Select Toshiba Utility and switch on the Power.
The hdd spin up and nocking for ~30times. All LED in statusregister where Grey.
Klick the autodetect, the hdd is detectet korrectly,
now start util, the hdd ist clicking for next ~30 times and ERR licgt in red.
Here the log:
ATTENTION!
HDD Is currently locked.
You may use command "Work with service area" / "Password removal" to unlock the HDD.
Techno On............................... : Ok
Zone table.............................. : Ok
Cyl num................................. : 219 226
Head num................................ : 2
Vendor.................................. : TOSHIBA
Model................................... : MQ01ABD100
Microcode............................... : AXF01C1H
G-List reading error.................... : G-List read error; Device Error Detected 01/19 (AMN;<bit3>;INF)
CP Avalable............................. : 33,34,44,56,92,95,98,9A,9C,A2,A5,A7,A8,A9,AA,AD,AE,B1,B3,BB,BF,C1,C5,C6,C7,C8,C9,CB,CD,D0,D1,D3,D4,D6,D7,D9,DA,DB,DC,DD,EF,F1,F3,F4,F7,F8,FA,FB,FC,FF
I try tu unlock, but no success.
In Modul test i see the cp DD cannot be reed.
Without the P-List i could not be solve PLIST Problem.
Changing the Heads, -same Problem.
So i think the Main Problem is: P-List could not be reed.
Is there a Chance to recover the data?
Any sugestions?
Thanks for answer.
Bruno
Here the log:
ATTENTION!
Any sugestions?
Thanks for answer.
Bruno
