TOSHIBA MQ02ABF050
Posted: 21.02.17, 12:54
by redlabs
HI
i got a TOSHIBA MQ02ABF050 in which is not reading sector what could be the problem
Re: TOSHIBA MQ02ABF050
Posted: 22.02.17, 11:39
by Amarbir[CDR-Labs]
Write a Proper Message Explain What You did Whats The Issue Properly How Can anyone Help You Otherwise
Posted: 02.03.17, 10:59
by redlabs
Hi Friend
we don't did anything as of now
Techno On............................... : Ok
Zone table.............................. : Zone table read error; Device Error Detected 51/20 (<bit5>)
G-List reading error.................... : G-List read error; Device Error Detected 51/26 (TON;ABR;<bit5>)
CP Avalable............................. :
When try to read sector found error below
Read sector (0-1) ext error device error detected "AMN;(bit5);UNC;BBK
and we did selecting other modal and trying clear G-list and rest the password and clear the SMART
still same
Posted: 02.03.17, 11:02
by redlabs
HI
if i select ABF model find the log below
Zone table.............................. : Ok
Cyl num................................. : 208 403
Head num................................ : 2
Vendor.................................. : TOSHIBA
Model................................... : MQ02ABF050
Microcode............................... : HDF01K0G
Defects in G-List....................... : 0
CP Avalable............................. : 33,34,44,56,92,95,98,9A,9C,A2,A5,A7,A8,A9,AA,AD,AE,B1,B3,BB,BF,C1,C5,C6,C7,C8,C9,CB,CD,D0,D1,D3,D4,D6,D7,D9,DA,DB,DC,DD,EF,F1,F3,
Posted: 05.03.17, 15:07
by redlabs
Hi friends
please can you help
Posted: 12.03.17, 17:38
whats the issue then its working ?
Posted: 19.03.17, 10:51
by redlabs
I am also facing same issue ...All modules are reading good ..Glist 0 but not able to single LBA ,Any one please help me
Posted: 24.03.17, 11:07
by Filipp_TS
Hi to all.
Perform a diagnostic of drive and check what a problem it have exactly by this steps:
http://blog.acelab.eu.com/2045.html
Posted: 02.04.17, 10:20
Did it work for you guys
Posted: 03.01.19, 12:06
by digital
Hi everyone, I used the procedure of the link:
http://blog.acelab.eu.com/2045.html posted by @Filipp_TS on a HD Toshiba Model: TOSHIBA MQ02ABD100H and I have successfully accessed the data.
Thanks for sharing everyone.
