PC-3000 Forum
http://forum.acelab.eu.com/
Toshiba MQ01UBF050
http://forum.acelab.eu.com/viewtopic.php?f=147&t=8856
Page
1
of
1
Toshiba MQ01UBF050
Posted:
14.04.16, 10:45
by
eisltd_adam
Hello guys. Quick question. Which utility I can use to start this drive?
Best Regards
Adam
Re: Toshiba MQ01UBF050
Posted:
14.04.16, 19:24
by
Have you adapted it to SATA? I don't think PC-3000 can work with USB Toshiba at all.
After you switch the PCB to SATA you should be able to work with it using the MQ01ABD utility.
Posted:
15.04.16, 10:44
by
eisltd_adam
Thank you
Posted:
15.04.16, 10:44
by
eisltd_adam
Thank you
Posted:
18.04.16, 17:43
by
Hi ,
How did The Case Go ?.Can you Shed Some Light
Posted:
22.04.16, 10:52
by
Filipp_TS
Hi to all.
What exactly is not clean regarding this case?
Also, new software version 6.1.12 is support Toshiba drives connected thru USB connection
