toshiba MK8032GSX Fuse
Posted: 11.01.10, 02:19
by ccamargol
Could any one mark the Fuses for Toshiba GSX laptop drive.
Thank you,
Carlos
- MK8032GSX.JPG (40.29 KiB) Viewed 3811 times
Re: toshiba MK8032GSX Fuse
Posted: 11.01.10, 16:10
by labtech
Usually its the first thing on the board on the line coming in from +5V on the SATA power plug.
Posted: 13.01.10, 22:44
the photo is not clear enough. usually you can find it beneath the 'F1' just beneath the data connector and is a small component with a letter 'N' printed on it. May not be exact the same, but should be good place to start.
Also, looks like you got yourself a ROM chip here, so ROM swap to another PCB could work.
