toshiba info
Posted: 23.02.09, 11:40
by compuman
hi to every one
could someone please tell me how shall i connect the usb terminal on a sata toshiba because i am gettins some errors! or if there are some updates which i have to install them?
Re: toshiba info
Posted: 25.02.09, 09:46
by dmarques
Why do you need to connect the usb terminal to Toshiba drive?
Re: toshiba info
Posted: 03.03.09, 16:55
by Alberto
toshiba doesnt has terminal log from startup like Seagate until im know
Re: toshiba info
Posted: 25.03.09, 10:45
by steven
there is a terminal access for Toshiba. But it is not so important
Re: toshiba info
Posted: 10.08.10, 14:00
by tec
Please supply terminal connection layout for Toshba SATA drives.
Re: toshiba info
Posted: 13.08.10, 07:56
by ddr
I also require the toshiba SATA terminal connection layout. You do need to connect terminal to allow capture of the CP modules?
Joel
Re: toshiba info
Posted: 13.08.10, 08:08
by ddr
Found a diagram on another forum.. Worked well..
- pins.GIF (3.09 KiB) Viewed 10123 times
Re: toshiba info
Posted: 13.08.10, 14:02
by tec
Thank you
Re: toshiba info
Posted: 07.06.12, 16:53
by gterry
Is the ground pin required? On the deepspar forum they only show the txd/rxd connected.
Re: toshiba info
Posted: 07.06.12, 18:04
You need only TX and RX attached to the middle jumper pins.
At terminal window hit "Enter" you should see a ">" sign if terminal is correctly attached.
IF not, switch positions of TX + RX connections.
Re: toshiba info
Posted: 07.06.12, 19:02
by gterry
Thanks!!
