TOSHIBA MQ04UBD200 in sector edit same LBA different information
Posted: 21.03.21, 20:48
Please I need to understand what is happening because I cannot find information to explain what I am looking.
1. I received a drive Toshiba MQ04UBD200 (USB) clicking
2. Change heads with a donnor.
3. Change PCB with a compatible one G4311A and I program the chip with a ROM programmer.
4. Drive was not clicking and PC3000 detected and read fast.
5. Made a HDD Resources Backup.
6. With Sector edit I could read the LBA 600.000 (Image 1): (https://drive.google.com/file/d/16QvtmC ... sp=sharing)
7. I could see the structure folder.
8. Turn off drive.
PROBLEM:
9. I disconnected the drive and after a while I connected again and now I cannot see the folder structure
10. Change heads again with a brand new donnor (though was heads damaged), but same behaivor, cannot see the folder structure.
PLEASE Help me to understand this
With sector edit I read the LBA 600.000 (as before) and now the information is different (image2 after): https://drive.google.com/file/d/1GJ6fVE ... sp=sharing
Why the information I read with the same sector edit is different?
Thank you
8. Turn off drive.
PROBLEM:
:With sector edit I read the LBA 600.000 (as before) and now the information is different (image2 after): https://drive.google.com/file/d/1GJ6fVE ... sp=sharing
Thank you
