MQ02ABF050H cannot read sector
Posted: 03.11.20, 05:06
by thanhtn
Hi all
I am having a Toshiba MQ02ABF050H hard drive
it boots up looks so ok
but sector cannot be read
I have done like instruction https://blog.acelab.eu.com/2045.html
and link https://blog.acelab.eu.com/pc-3000-for- ... rives.html
and link https://forum.acelab.eu.com/viewtopic.php?f=147&t=7732
but all failed
help me please!
Re: MQ02ABF050H cannot read sector
Posted: 03.11.20, 09:00
by northwind
Does terminal say
SIGNATURE SCAN FAILED
Posted: 04.11.20, 03:00
by thanhtn
@nothwind Didn't see that message
Posted: 04.11.20, 09:26
by northwind
Could you connect terminal and power up the drive? And post screenshot of terminal window here?
Posted: 04.11.20, 17:15
Looks like a NAND issue to me, needs to be flushed over terminal
Posted: 05.11.20, 03:35
by thanhtn
northwind wrote:Could you connect terminal and power up the drive? And post screenshot of terminal window here?
there is a notice like in the picture, my friend
Posted: 05.11.20, 03:38
by thanhtn
AJ2008 wrote:Source of the post Looks like a NAND issue to me, needs to be flushed over terminal
Can you guide me to fix it?
Posted: 05.11.20, 17:40
by MasterT
Toshiba SSHD (Hybrid drives)
Work with Service Area --> HDD Configuration Changing --> Flash Permanent Cache --> OFF
Or issue >NVA command in terminal and Restart Drive.
Posted: 06.11.20, 11:26
thanhtn wrote:Source of the post
MasterT wrote:Source of the post Toshiba SSHD (Hybrid drives)
Posted: 09.11.20, 15:43
by thanhtn
MasterT wrote:Toshiba SSHD (Hybrid drives)
Flash permanent cache parameter: it was faded and cannot be turned on or off
MQ02xxx I think it's not supported
Posted: 13.01.21, 13:31
by Filipp_TS
It's supported.
And NAND can be disabled - that's a solution.
As was mentioned - connect terminal adapter, launch Toshiba utility and select ang MQ****H family name (important that 'H' in the end of family name).
then go to Work with Service Area --> HDD Configuration Changing --> Flash Permanent Cache --> OFF as was mentioned.
Then check sector access - should be available.
