Toshiba Mk5065gsxn HDD IS CURRENTLY LOCKED.
Posted: 14.06.19, 23:56
by tonoarimany2012
Hi Guys
i have this toshiba MK5065GSXN With this message
ATTENTION!
HDD Is currently locked.
You may use command "Work with service area" / "Password removal" to unlock the HDD.
Techno On............................... : Ok
Zone table.............................. : Ok
Cyl num................................. : 164 367
Head num................................ : 4
Vendor.................................. : TOSHIBA
Model................................... : MK6465GSXN
Microcode............................... : GH101M8
Defects in G-List....................... : 1912
CP Avalable............................. : 51
Any Ideas?
Re: Toshiba Mk5065gsxn HDD IS CURRENTLY LOCKED.
Posted: 15.06.19, 06:48
by hdd00
The hdd is locked with ATA password...You must remove it using the utilities menus.
Posted: 15.06.19, 08:36
by digitalsupport
Lots of ideas here,
Unlock and extract data and keep an eye on any trouble related to G-List
Posted: 15.06.19, 21:29
by tonoarimany2012
Thank you for your help
i'm new with data recovery
do you know where can i find any tutorial how to unlock it thank
Posted: 16.06.19, 18:32
by Takanashi_Hina
:shock: :shock: :shock:
There should be an option to do so on the menu of the Toshiba utility ?
Just detect the drive using PC-3000 Toshiba utility and check the menus ?
Fot Toshiba SATA all that it takes for the majority of cases is SUPER ON + VSC to regen "S" sector on platter ....
When you detect the drive with the Toshiba utility you can see this :
Means that the drive did accept the "SUPER ON" already . Now with the drive on that state go to the top bar of the PC-3000 TOSHIBA tool that you have opened and find there the option to remove the ATA password. There are 2 options one is to use the vendor specific command to tell the drive to regen the "S" sector on the platter and the other is to read the "S" sector by PBA and replace it by one of unlocked drive. PC-3000 should support both methods. Good thing about 2nd method is that you can write back original "S" sector to get the drive locked again with the exact same ATA password .
Posted: 17.06.19, 06:22
by digitalsupport
Have a look in the Toshiba manual @ page 42
Posted: 18.06.19, 08:40
by northwind
tonoarimany2012 wrote:Source of the post You may use command "Work with service area" / "Password removal" to unlock the HDD.
