Toshiba MK8050GAC ATA lock
Posted: 15.03.19, 14:06
by DCC-PC3K
Hi, I have a Toshiba MK8050GAC which is ATA locked. Does anyone know if any of the families in the Toshiba utility would support ATA unlocking?
Thanks.
Re: Toshiba MK8050GAC ATA lock
Posted: 15.03.19, 19:12
by Takanashi_Hina
The VSC (Vendor Specific Command) to re-create the "S" (Security) sector on the platter and re-set the password to the default should be the same for all IDE TOSHIBA and another VSC is used for SATA TOSHIBA.
You have IDE drive so if PC-3000 is using the correct ATA VSC to re-create security and unlock the drive ANY utility for Toshiba 2.5 IDE (PATA) drives should work ... This doesn't apply if the PC-3000 uses the method of reading S "sector" by PBA directly .... At any rate should be very easy to unlock ...
