MQ04UBB400
se134
MQ04UBB400
Postby se134 » 21.08.24, 10:14
Hello everyone.
I have a MQ04UBB400 which is not recognized.
DISK DRIVE MQ04UBB400
DRIVE REV AZA AE02/JS0B0U
DATE:18JAN2023
MADE IN PHILIPPINES
Is this not supported by pc3000?
I changed the PCB interface from USB (G0090A) to SATA (G4311A).
Of course I read the G0090A ROM with a ROM programmer and wrote to the G4311A ROM.
When I read it with DE, there is no partition and the data seems to be encrypted.
I checked the CPU on the PCB and found that the G0090A and G4311A seem to be different. Is this the reason why data cannot be accessed?
Does anyone have a solution?
Masterclass
Re: MQ04UBB400
Postby Masterclass » 22.08.24, 08:26
se134 wrote:Source of the post there is no partition and the data seems to be encrypted
most probably data is shifted because of sa failure. Never seen hw crypted tohibas
se134
Re: MQ04UBB400
Postby se134 » 22.08.24, 09:16
Thanks for the reply, Masterclass.
But I got a normal donor MQ04BBU400 and changed the PCB from G0090A to G4311A in the same way, but I cannot see the partitions and data on the DE.
The following article says that G0090A and G4311A are fully compatible, but I think they have different CPUs and are not compatible.
https://forum.acelab.eu.com/viewtopic.php?f=147&t=10087
d_d_recovery
Re: MQ04UBB400
Postby d_d_recovery » 22.08.24, 17:56
Can you post a picture of sector 0.
se134
Re: MQ04UBB400
Postby se134 » 23.08.24, 07:23
Thanks for the reply, d_d_recovery.
Sector 0 is not readable.
Because the head clicks at startup.
It will be DRD,DSC in about 1 minute.
I thought the patient's MQ04BBU400 may have a broken translator or may not have been initialized by SA.
I don't know the details as it is not supported by Utility.
Hopefully it will be supported by PC3000 in the near future.
In addition I am sure that PCB G0090A will be fully compatible with G4311A.
Thank you very much.
Return to “Toshiba native”
