Unknown Partitions
odedshankar
Unknown Partitions
Postby odedshankar » 13.05.15, 11:51
Hi Guys,
I got a Toshiba Laptop HDD 640GB 2.5" which the customer advised that was faulty and replaced by a tech.
He advised that he had 2 partitions C & D and he needed data from both.
He advised that the tech managed to extract everything from C Partition but couldn't see D partition at all.
I imaged the drive first using DDI and had 120 bad sectors but managed to get them all so no dramas here.
But when i accessed the drive could see only C, after complete scan with several tools, i can't see D partition only few partitions of a type i am not familiar with.
Did anyone experienced something similar? that is the first time i see this.
See image below:
https://dl.dropboxusercontent.com/u/495 ... n-Tree.jpg
Cheers
Re: Unknown Partitions
Postby AJ2008 » 13.05.15, 12:03
0x42 is extended partition marker and is required due to limitations in the volume of partitions possible in basic MBR tables. I remember a case where client had over 20 partitions present, each one I had to save individually...
For this case did you mount it and check it with other software like r-studio that may better identify any active volumes?
odedshankar
Postby odedshankar » 13.05.15, 12:39
Hi Mate,
I tried to scan it with R-STUDIO and it sees lots of partition as EFISECTOR FAT12 type - so don't know. Didn't get real result.
But i tried now MiniTool and it sees this volume as spanned NTFS so i'm giving it a try - scanning it now - will see how it goes.
Cheers
Return to “Toshiba native”
