MK3265GSXN
MK3265GSXN
Drive stays busy, although actuator calibrates and settles. Have confirmed that the actuator is good. I suspect possible corrupt Glist, but drive not supported by PC3000. Can anyone help with possible terminal access to overcome problem.
Re: MK3265GSXN
Have you tried to work with this drive via 63GSX family? Or "Other SATA"?
Terminal should be connected like on attached picture.
