Page 1 of 2
whats' the easiest way to connect 8 drives to a PC?
Posted: 12.02.18, 21:14
by osity
Of course I could use 8 HDD docs but that's a bit nuts.
I was thinking of using a PCI-e 6 port SATA controller and two onboard SATA controllers. Or I could go with 2X 4 port controllers.
If this is a good approach, can anyone recommend a reliable controller? I've heard bad things about SYBA.
Re: whats' the easiest way to connect 8 drives to a PC?
Posted: 12.02.18, 23:15
by thatdellguy
LSI SAS 9211-8i
Posted: 12.02.18, 23:31
by osity
I noticed that one has RAID.... Is there a non raid version?
In the pic it doesn't show 8 ports. I'm assuming I can just not use the RAID function?
Posted: 12.02.18, 23:44
by thatdellguy
Can be flashed into IT mode.
Posted: 13.02.18, 00:14
by Blizzard
Look for a mini-SAS to 4x SATA cable.
Posted: 13.02.18, 01:07
by osity
Oh the connecters on the card are mini SAS?
So I guess you don’t get any cables with it.
it sounds like I would need the card and two mini Sas to 4x SATA cables...
I just ordered it with the a bunch of cables. Thank you!
Posted: 13.02.18, 04:28
by thatdellguy
1. card
2. flash to IT mode.
3. two sets of cables.
Posted: 13.02.18, 05:33
by osity
That card is a beast... it can handle 256 drives
Posted: 13.02.18, 09:51
It needs to be HBA card not RAID controller - RAID controller often will not mount drives unless they are an active RAID configured by the card. HBA will simply mount them as individual disks.
Posted: 13.02.18, 14:54
by lcoughey
Any of the Microsemi HBA 1000 Series adapters should do the trick -
https://www.microsemi.com/product-direc ... 60-hba1000If you are looking for a short-term quick and dirty approach, another alternative is an 8 port USB3/eSATA hotswap enclosure by Startech -
https://www.startech.com/HDD/Enclosures ... 358BU33ERM
Posted: 16.02.18, 15:20
by osity
It seems flashing to IT mode was unnecessary.
Posted: 25.02.18, 09:01
Well,
A HBA SAS with Card To SATA Cables .Or a SAS Raid card that can be flashed to HBA
Posted: 05.03.18, 18:49
by drdoc
startech 8 drive enclosure - $391
or
or couple of 5 port stat multiplier cards on ebay $17 each....
you know, sata is cascadeable, you plug your sata cable into the port multiplier and it becomes 5 sata ports.
you need the appropriate sata controller - but I think its standard with all the recent (last few years) sata cards, check your sata specs.
Posted: 23.10.19, 07:08
by kennethwy
Good day,
We received a RAID 6 NAS unit with 16 drives NAS, 6TB/ drive. All drives are in working condition but a LUN has done missing after reboot.
What is a better (faster) approach to due with this case?
Posted: 23.10.19, 13:44
by d_d_recovery
You need a none RAID SAS controller. If you get a SAS controller you can attach SATA or SAS drives to it.
