Generate good / bad file lists
Posted: 14.07.18, 10:46
by SlingShot
Is it possible to generate a file list based upon the good or bad files only ?
For the good
Can a list be generated of just good files ?
For the bad:
Got this sorted.
Re: Generate good / bad file lists
Posted: 14.07.18, 20:23
by thatdellguy
Brian showed me this and it works for getting a list of good files only.
viewtopic.php?p=35030#p35030
Posted: 15.07.18, 00:22
by SlingShot
I must be missing something as I can't get that to work, get as far as checking boxes on the legend, but theres no option to select 'excluding' and it just generates a submap :|
Posted: 16.07.18, 23:17
by SlingShot
300ddr wrote:Source of the post @thatdellguy
Can DE produce only a list of good healthy files.
Make a snapshot (or deep scan) of partition then click "create submap using legend," check black/red/wiped/etc (any "bad" or unread sector) and on next pop-up click, excluding.
Cant get this to work, am I missing some steps not mentioned here ?
Posted: 17.07.18, 14:26
by SlingShot
Ok, so you have to pretty much do the job to get near making that list of good files, so may as well do the job and use 3rd party tools to generate that list.
