Task file repair
Posted: 12.05.18, 09:40
by AdasRip
Is it possible to repair a task in DE?
Today it turned out that both task.prm and task.bak files are damaged (empty).
The rest of the files looks correct.
For example, can you create a new task but import the already read data from the old task?
Re: Task file repair
Posted: 12.05.18, 21:10
by Blizzard
Preserve original files in case you need to get support from Ace.
You can create a new task > exit DE > copy map.bin from failed task > open the new task > select map tab if not on it > right click in map and choose recalc.
Posted: 16.05.18, 16:07
by AdasRip
It worked but unfortunately not quite.
When you try to scan mft + index everything loses in lost and found.
Previously, there was a nice directory structure.
Maybe something more was damaged.
Nevertheless, thank you for your help.
Posted: 24.05.18, 10:12
by Nick_TS
Did you change PC-3000 version when re-open the task?
Posted: 08.06.18, 14:30
by AdasRip
No, I didn't.
