data recovery from formatted HDD
geosou
Postby geosou » 26.08.16, 07:07
Any suggestions to recover a formatted HDD avoiding raw recovery.
Good day to all of you
johnchristy
Re: data recovery from formatted HDD
Postby johnchristy » 30.08.16, 08:41
Try partition analyz
Postby DataMedics » 30.08.16, 15:59
geosou wrote:Source of the post Any suggestions to recover a formatted HDD avoiding raw recovery.
If you can provide a better description, we can probably give a much better answer and give more guidance. For example, how was the drive originally formatted (NTFS, HFS+, FAT)? How did you format the drive (e.g. Windows, WD Smartware, etc.)? What did you format it to? Did you add any data, reinstall the OS, etc. after it was formatted? What type of memory storage device is it (HDD, SSD, Thumb drive)?
If you give us a nice story of what happened, we'll have a better picture of the current condition of the data.
Postby Amarbir[CDR-Labs] » 01.09.16, 10:36
DataMedics wrote:Source of the post
Hi Jared ,
I Agree With You ,But To the Thread Opener " If MFT Files Are Gone Then RAW is The Only possibility "
johnchristy
Postby johnchristy » 01.09.16, 14:46
wd model WD10JPVX-75JC3T0 size 1TB disk formatted and os re installed.can we recover in pc 3000? which option i need to select pls help.
hddr49
Postby hddr49 » 01.09.16, 15:29
Fast format or full format ?
OS re installed, not img restored ?
Postby DataMedics » 04.09.16, 17:07
Amarbir[CDR-Labs] wrote:Source of the post
Hi Jared ,
There's a lot more to an NTFS file system than just the MFT. There's the indexing in the middle of the partition, various folder/file structures stored across the data area, etc. Knowing what happened will provide a complete picture of the situation. Jumping to conclusions without getting the full story is a great way to waste a week chasing ghosts that don't exist.
Return to “Data Extractor”
