I could see all files and folders via DE but only some files from a folder could be opened correctly, all other files are not opened , I mean are corrupted, I started to see the each files "View the first Sector". I could be see only '0" sector. ie
0x0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0140 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0150 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0160 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0180 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x0190 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x01A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x01B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x01C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x01D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x01E0 00 00 ..
also i can read successfully the sector..
Any solution for this Problem, please let me know..
Betty
Crystal
Seagate files corrupt
Re: Seagate files corrupt
What read options are active? Do you know the problem with the case?
If that empty sectors represents a folder or file then the file may have an entry in MFT but actual data looks gone, unless reading is made with error or there is some underlying problem somewhere.
But if HDD is healthy with no problems and you are reading with normal read options, then maybe the data is not recoverable where sectors are empty...
I had used "default" options
ie read UDMA66 , then I used " Do not use Hardware retries",.
Betty
Crystal
Betty
Crystal
Either is erased at the surface, or could be part of some multi-disk unit or array system?
Can elaborate little more, please?.. and any solution ?
betty
Crystal
betty
Crystal
