formatted disk
Posted: 06.08.13, 14:05
by Yury
I have PC disk WD320DDAAKS not damaged formatted by user. After disk analisys I putted user name to GREP in order that to find all files in profile and I got 22000 objects. Did I do everything right on this point and what I should do further to sort out the files?
Re: formatted disk
Posted: 29.08.13, 19:10
by Towerrat79
Hello Yury
Is there any reason that you did not use the Quick Disk Analysis? This will search the drive for the various file systems which were contained on the drive. You could also run Search NTFS Structures to see if some of the file system can be recovered.
Frank
