Wish list in DE
Posted: 01.01.12, 10:53
by einstein9
Dear Developers
Really it would be really good to have this option fixed in DE
when selecting multiple folders for extraction (save) the Indicator does not show the total size in GB
i noticed this in all DE versions even with the latest update.
sometimes i need to know which external hdd will be used here to fit all exported files/folders
thank you
Re: Wish list in DE
Posted: 22.08.12, 18:54
by einstein9
For many many times i asked Technical Support to fix this issue in DE
i tried to explain it by text but no one was listing
here is the attached image which explains it the total size of selected folder is not showing
hope this will be fixed in next update
thank you
Re: Wish list in DE
Posted: 24.08.12, 03:37
by 300ddr
Something you probably already know, but in case you don't: you can get the correct size by checking desired folders, generate map of selected files, choose something like "calculate size." This is a new feature so you may have missed it. Doesn't solve the "bug" but may help you.
Re: Wish list in DE
Posted: 25.08.12, 20:16
by einstein9
i know what you mean, and am sure YES
but this is not the point...
do u know how LONG does it take? this is the question
Re: Wish list in DE
Posted: 28.08.12, 03:37
by 300ddr
Depending on the amount of files, it may be 1-20 minutes. Subsequent scans/calculations will be faster after the initial one. I don't think the size displayed that you show in your pictures could be correct before all the folders were traversed and sizes calculated.
Re: Wish list in DE
Posted: 16.09.12, 18:21
by einstein9
I don`t know if i post this before or not, but here again am writing
It would be nice really in DE Grep Search Import/Export Option
I added some of the Unknown Extensions or some of them are not listed in RAW Recovery mode.
i was thinking of a better way to IMPORT it to the list of existing instead of Adding AGAIN one by one
Import can be done via either from TEXT or XML format file
thank you
