Serious logical recovery issue
Posted: 03.07.09, 03:57
I've a Maxtor 6E020L0 (20GB). The drive is good working order. When plugged into the normal ide port Windows shows the drive as D: but when clicked, no directory/file is listed at all, a complete blank. On some occasions, Windows would ballooned a massage at the lower right task bar saying the directory/file structure is damaged and recommending the use of chkdsk. Of course we all know that chkdsk is the worst program to use in such situation! So it wasn't used.
Now, both DE and R-studio were able to recover the COMPLETE directory & file structure; everything seemed PERFECT. However, when files were randomly selected and opened, they all appeared showing gibberish chars. For example I opened a .html or a .txt file, instead of seeing normal readable text, I saw extended ascii chars all over while plastered with some familiar readable text from other files.
It seems to me that although the directory/file structure is intact, the data addresses associated to each file are corrupted or have been shifted some what.
Is there anyway to rescue the files? Thanks.
Jeff
Jeff
