Re: Recovery software for XFS filesystem
Posted: 30.01.09, 12:06
by manel
When XFS filesystem is damaged nowadays the only way to recover files is in raw mode. I mean, not possible to get the logical structure again. Also if files are removed with folders happend the same.
Posted: 30.01.09, 12:25
manel wrote:When XFS filesystem is damaged nowadays the only way to recover files is in raw mode. I mean, not possible to get the logical structure again. Also if files are removed with folders happend the same.
This is because the filesystem is journalled. It is possible to access XFS systems with UFS explorer, but only rarely will you manage to retrieve structured data when FS is damaged unfortunately.
Posted: 30.01.09, 13:05
by manel
Exactly, this is I wanted to say :D . You can access data but not with logical structure. UFS explorer and others, recover files and put on different folders with this parameters:
JPG Recovered Files
Avi Recovered Files
Mpg Recovered Files
Txt Recovered Files
etc.
And all files found are put on this folders with out any logical. So If you've for example 3 or 4 users on same hdd with "critial" photos it's a good idea to call client first... :mrgreen:
Posted: 04.02.09, 14:17
by Emil
Coping files from a XFS file system can be done easily with a linux machine (suse or other):
mount -t xfs -o ro,norecovery /dev/[h,s]d? /mount
if your file system is not damaged you will see the data and can copy it.
If your file system is damaged use xfs_check and xfs_recover. More info in the man pages.
Emil
Posted: 04.02.09, 14:44
by manel
Emil wrote:Coping files from a XFS file system can be done easily with a linux machine (suse or other):
Emil
xfs_check or xfs_recover it's agresive like scandisk from windows? I mean if something is wrong it try to repair or convert to a file like CHK (from windows). I say this because if something is deleted and it starts to repair doing files like windows... perhaps will destroy some data.
Posted: 04.02.09, 15:15
by Emil
Emil
It goes without saying that you do this on a mirror copy of the original drive (with Data Extractor) - actually the right way to do it is to make a mirror disk and then a mirror of the mirror. If your file system is not severely damaged chances are high you will get pretty decent result - much better than a raw recovery.
Posted: 05.02.09, 08:56
by manel
Emil
I know that this MUST BE DONE on a mirror from the original :mrgreen: , but I was asking for the method that xfS_check or xfs_recover do. Anyway if chances to recovery are pretty decent instead of raw recovery I'll try this afternoon and post coments tomorrow.
Thx in advance.
