Seagate 500GB platter seizure
Re: Seagate 500GB platter seizure
You should replace the platters on the other disk or maybe replace the stuck spin motor.
They probably solved this issue since 2006
pepe
pepe
Pepe wrote:Hi,
pepe
Dates on forum are bit stranges. Sometimes appears correctly. Others no, anyways thanks for correction
We sucess on free the spindle, with seagate 500GB, but the heads doesnt move stay on land zone , and spindle seized, im trying the same method with 7200.11 but on this case not reach readiness, and the second reach then lost it, but this cases was dropped, heads moved to the begin of platters , maybe this caused missalignment,
