Accidental clearing of the map (green cubes) in the DE task...
Posted: 12.10.24, 00:55
Hello everyone,
I accidentally cleared (via "clear map" in DE) some of the mapped sectors (correctly read - green cubes) in DE.
Unfortunately, the source disk condition has degraded - and I can no longer easily read these sectors again.
Is there any information in the task (in task directory with the image file) about previously read and now cleared sectors ?
Is it possible to somehow copy (read) these sectors that were in green cubes - and are now white (as unread) ?
Unfortunately, I do not know which "green cubes - sectors" I cleared via "clear map"...
Correct reading was performed to "file image" files...
I have one more question...
In "task statistic" - (legend) it shows me negative (with a minus) numbers of sectors (e.g. black cubes or yellow cubes). These negative values ??are even after full clearing of the map - via "clear map".
This is not the first time I have encountered such a case...
What does this mean?
Thanks in advance for any help.
Best regards.
Best regards.
