Drive was had full file system witll folder structure, today its gone.
Posted: 31.08.22, 19:51
by osity
F3 drive was repaired and had full access to HFS file system. After imaging for a several hours, drive randomly stopped.
Tasks was closed for the night and after restarting the task later the following day the file system and folder structure is gone.
All i get now is: 1[EE] EFI GPT and it doesnt expand.
Drive is still functional with full sector access.
Any idea why or how I may have lost the file structure? How can it be prevented in the future other than not closing a task?
Log shows:
Task parameters saving: 8/31/2022 1:56:51 PM
(LBA + Count - 1) <0!partition_entry_array not read
Init Primary EFI_GPT failed
EFI_GPT_Header valid
Try [EFI_GPT_Header.alternate_lba]
[EFI_GPT_Header.alternate_lba] read OK
Init Secondary EFI_GPT failed
Re: Drive was had full file system witll folder structure, today its gone.
Posted: 31.08.22, 20:01
by d_d_recovery
Have you mapped the catalog file again and then scanned it?
That should rebuild it for you.
Posted: 31.08.22, 20:32
by osity
That was my first thought also but the error in the log is about GPT, so I don't think the PC3K sees that it's a HFS+ file system so it won't give me that 'ScanCatalog' option.
All I get in the directory structure now is :
+0-PC3000 SATA 1 (PhysicalSector = 4096)
1[EE] EFI GPT
I've also tried a Quick 'disk analysis' and 'search FS structures'.
Posted: 31.08.22, 20:36
by d_d_recovery
Have you tried changing sector size from 4096 to 512?
Posted: 31.08.22, 20:40
by osity
lol, I literally thought of that just before you suggested it but I hesitated to try it for some reason.
That solved it d_d_recovery! ....and no scan catalog needed.
Thanks so much for your suggestion and your prompt reply!
Posted: 31.08.22, 20:41
by osity
Why would it need to be handled as 512 now anyway? Drive has AF label on it and I didnt have to set it to 512 yesterday.
Perhaps it set it to 512 automatically yesterday?
Posted: 31.08.22, 20:46
by d_d_recovery
I am just trying to give you options.
Posted: 13.03.23, 04:49
by gameboybin
d_d_recovery wrote:Source of the post changing sector size from 4096 to 512
Hi Desert Data Recovery. Sorry for digging such an old post. How can i Change Sector size form 4096 to 512 in DE?? I dont seem to find anywhere to change that??? Can you walk me through???
I Got a TOSHIBA drive, upon DE, It tells me i need to change sector size from 4096 to 512 but i can't find it anywhere to change that???
Thank you!
Posted: 13.03.23, 15:43
by d_d_recovery
Right click on PC3000 SATAX in the folder tree.
Its near the bottom of the menu.
Depending on your version of PC3K it may be slightly different.
