Drive was had full file system witll folder structure, today its gone.
osity
Postby osity » 31.08.22, 19:51
F3 drive was repaired and had full access to HFS file system. After imaging for a several hours, drive randomly stopped.
Tasks was closed for the night and after restarting the task later the following day the file system and folder structure is gone.
All i get now is: 1[EE] EFI GPT and it doesnt expand.
Drive is still functional with full sector access.
Any idea why or how I may have lost the file structure? How can it be prevented in the future other than not closing a task?
Log shows:
Task parameters saving: 8/31/2022 1:56:51 PM
(LBA + Count - 1) <0!partition_entry_array not read
Init Primary EFI_GPT failed
EFI_GPT_Header valid
Try [EFI_GPT_Header.alternate_lba]
[EFI_GPT_Header.alternate_lba] read OK
Init Secondary EFI_GPT failed
d_d_recovery
Re: Drive was had full file system witll folder structure, today its gone.
Postby d_d_recovery » 31.08.22, 20:01
Have you mapped the catalog file again and then scanned it?
That should rebuild it for you.
osity
Postby osity » 31.08.22, 20:32
That was my first thought also but the error in the log is about GPT, so I don't think the PC3K sees that it's a HFS+ file system so it won't give me that 'ScanCatalog' option.
All I get in the directory structure now is :
+0-PC3000 SATA 1 (PhysicalSector = 4096)
1[EE] EFI GPT
I've also tried a Quick 'disk analysis' and 'search FS structures'.
d_d_recovery
Postby d_d_recovery » 31.08.22, 20:36
Have you tried changing sector size from 4096 to 512?
osity
Postby osity » 31.08.22, 20:40
lol, I literally thought of that just before you suggested it but I hesitated to try it for some reason.
That solved it d_d_recovery! ....and no scan catalog needed.
Thanks so much for your suggestion and your prompt reply!
osity
Postby osity » 31.08.22, 20:41
Why would it need to be handled as 512 now anyway? Drive has AF label on it and I didnt have to set it to 512 yesterday.
Perhaps it set it to 512 automatically yesterday?
d_d_recovery
Postby d_d_recovery » 31.08.22, 20:46
I am just trying to give you options.
Postby gameboybin » 13.03.23, 04:49
d_d_recovery wrote:Source of the post changing sector size from 4096 to 512
Hi Desert Data Recovery. Sorry for digging such an old post. How can i Change Sector size form 4096 to 512 in DE?? I dont seem to find anywhere to change that??? Can you walk me through???
I Got a TOSHIBA drive, upon DE, It tells me i need to change sector size from 4096 to 512 but i can't find it anywhere to change that???
Thank you!
d_d_recovery
Postby d_d_recovery » 13.03.23, 15:43
Right click on PC3000 SATAX in the folder tree.
Its near the bottom of the menu.
Depending on your version of PC3K it may be slightly different.
Return to “Data Extractor”
