When I try to export using the 'export data to another drive' feature I get the following error. .
Posted: 17.08.22, 16:54
by osity
Write error!
TSysDrive.WriteData - (ReturnCode <> WAIT_OBJECT_0) or not GetOverLappedResult
I'm Ive tried to export to a drive with the same LBA or larger.
Has anyone experienced this before?
Re: When I try to export using the 'export data to another drive' feature I get the following error. .
Posted: 17.08.22, 19:12
by osity
After trying about 4 different drives, the fourth one worked. Might be an issue with destination hard drives having minor undetected faults.
Posted: 24.08.22, 22:35
by digitalsupport
Did you wipe or delete partitions on the destination drive before you write to them ?
Posted: 24.08.22, 23:11
by osity
I don't recall for sure but I think I did. Is that a requirement that the drive be unpartitioned?
Posted: 25.08.22, 13:25
by digitalsupport
If there are partitions on the drive, windows will "try" to protect them.
Could be the reason for your trouble.
Posted: 26.08.22, 02:04
by osity
I will take note!
