Seagate momentus 5400.6 LBA & ABR Error
Posted: 21.05.20, 06:00
by ddcywf
hi,
I am facing LBA error followed by ABR error while performing the Quick Disk Analysis (snapshot attached). I don't understand what to do with it. I am also unable to open the dis drives which gives "Root Dir is not valid operation aborted" error. Kindly help in recovering the data.
- 1.jpg (4.6 KiB) Viewed 20314 times
Re: Seagate momentus 5400.6 LBA & ABR Error
Posted: 21.05.20, 08:57
by northwind
There is one partition missing. The one that you show is not your main partition.
Run raw recovery on your drive and show results here.
Posted: 21.05.20, 09:07
by Nick_TS
Are all sectors readable on the drive?
Posted: 28.05.20, 07:56
by ddcywf
Editing of sectors shows zeros
Posted: 03.06.20, 05:49
by ddcywf
The Raw Recovery results snapshot is attached herewith
- raw recovery 1.jpg (6.4 KiB) Viewed 20253 times
Posted: 05.06.20, 08:26
by ddcywf
The problem still persists kindly help
Posted: 05.06.20, 17:27
by d_d_recovery
If you look at your first picture posted, look at the status registers. You have issues with this drive. I suspect its bad heads. Can you post the terminal readout.
Posted: 06.06.20, 13:29
by digitalsupport
+1, drive has problems that needs to be taken care of before imaging.
