hi,
I am facing LBA error followed by ABR error while performing the Quick Disk Analysis (snapshot attached). I don't understand what to do with it. I am also unable to open the dis drives which gives "Root Dir is not valid operation aborted" error. Kindly help in recovering the data.
Seagate momentus 5400.6 LBA & ABR Error
Moderator: Alex_TS
Re: Seagate momentus 5400.6 LBA & ABR Error
There is one partition missing. The one that you show is not your main partition.
Run raw recovery on your drive and show results here.
Are all sectors readable on the drive?
Dmitriy_TS wrote:Source of the post Are all sectors readable on the drive?
Editing of sectors shows zeros
northwind wrote:Source of the post on your drive and show results here.
The Raw Recovery results snapshot is attached herewith
The problem still persists kindly help
- d_d_recovery
- New user
If you look at your first picture posted, look at the status registers. You have issues with this drive. I suspect its bad heads. Can you post the terminal readout.
- digitalsupport
- New user
+1, drive has problems that needs to be taken care of before imaging.
